Hp15 failure ID: 9sp87h-82L8L9-MFPX61-60FB03
My HP15-1039wm laptop reads; Selected boot image did not Authenticate. Press to continue. I've done this as well as pressed f11, but the computer keeps shutting down. What should I do now?
try to disable secureboot and enable legacy boot mode ( solution found on the net ) i assume this will be found in the bios ..hope this helps
Nov 29, 2015 | Computers & Internet
I just bought Hp15 touchsmart. It takes a long time to boot up. Is this normal?
Is the Operating System Windows 8?
Normally Win 8 will boot pretty fast, but if you are running a slow hard drive, the boot up process can still take some time.
Feb 12, 2015 | Computers & Internet
Changing Cartridge
Your Laserjet 3330 uses a toner cartridge, HP15, and to swap it out, you open the door just below the control panel, or above the paper tray. Once opened, the toner can be removed and replaced easily! Close the door after the new toner is installed, and you are good to go!
Apr 23, 2010 | HP LaserJet 3330 All-In-One Printer
We need the catridge number of a microboard PF-2 disc printer with serial no PRF 035434 and the Model is PRF-2000-01.
It uses the color cartridge HP23 OR HP41 (You'll need to confirm this, those are different cartridges) and the black is HP45 (40ml) or HP15 (20ml).
Oct 28, 2009 | MicroBoards PF-2 Disc Printer
I have a hp office jet v 40 series fax, scanner, and copier
Get rid of the HP 45, it is not compatable, even though it looks the same. Go buy the HP15 and the problem will be solved.
Apr 14, 2009 | HP Office Equipment & Supplies
Printer reads "Incorrect Print Cardtridge Installed"
According to the HP website, the correct cartridge for the HP PSC950 is HP15 or HP78. Comes in black only or tri-color.
Dec 22, 2008 | HP PSC 950 All-In-One InkJet Printer
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
