Where to buy a ML1200 cmos battery for all-in-one computer
How do I replace a y510 cmos battery
Locate your CMOS battery
Caution: When inside your computer make sure you're aware of ESD and all it's potential dangers.
cmos.jpgOpen the computer case and find the battery on the computermotherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery as shown in the image to the right.
If you are unable to locate your CMOS battery refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in locating it.
Obtain battery information
Unfortunately, most manufacturers will not list the exact type and model of your CMOS battery; therefore, once you have located the battery, write down all information about the battery (Voltage, chemistry, wiring, and packaging). If possible, remove the battery and take it to the location you plan on purchasing a new battery from. The part number for this battery for most computers is CR2032.
Additional buying information can be found on our battery buying tips page.
Removing the battery
If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Users with computers that do not have removable batteries only options to install a new battery will most likely also need to set a jumper when adding the new battery into their computer.
Insert the new battery
Once you have purchased a new battery, remove the old battery (as instructed above) and replace it with the new battery.
Enter CMOS values
Once the battery is replaced turn on the computer and resetting the CMOS values to the defaults. After the values have all been entered make sure to save the settings before exiting. Many CMOS setups allow you to press a key (such as F10) to save values and exit all in one action.
If after following all the above steps you continue to experience the same error when your computer starts or your computer is still unable to keep the stored values it's likely that you're experiencing a more serious issues. Most likely causes are bad power supply or bad motherboard.
Apr 19, 2012 | Lenovo IdeaPad Y510 Notebook
UkI have a Vaio VGC-VA1 that needs a new cmos battery, how do I get at it? Mike M.
hi you can buy the CMOS battery from this link
CMOS battery are just the same regardless of brand
try also at ebay they have various CMOS battery see it here
If the holder of the cmos battery is not exactly the same of your original battery you can just remove the battery from the holder and use the holder of the original battery.thank you.
Aug 17, 2011 | Sony VAIO PCV-W20 PC Desktop
The cmos battery is out of service. Where can i buy a new one?
You can purchase a CMOS battery from any local computer store in your area. If you don't know how to remove and connect the CMOS battery, I would suggest bringing your Acer Travelmate to any local computer shop or if you preferred, you can bring it to Acer Accredited Service Center.
Thank you,
Jack
Feb 17, 2011 | Acer TravelMate 2300 Notebook
Computer will not boot past POST and it shows "CMOS checksum error - defaults loaded" on the screen...
good day,
your cmos battery is weak(low voltage) it does not save your bios settings every time you configure it or set it to default settings, it will always display cmos error every time you shutdown your PC, try replacing it with a new one, check the old battery model and buy it in your nearest computer shop, commonly used battery in Motherboards is CR2032 Lithium battery..
Hope this helps.
Sir MArkus
Feb 01, 2011 | Computers & Internet
How to change cmos battery
cmos.gifOpen the computer case and find the battery on the computer motherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery as shown in the image to the right.
If you are unable to locate your CMOS battery you will need to refer to your motherboard or computer documentation and/or contact your computer manufacturer for additional assistance in locating it.
Caution: While in the computer make sure you're aware of Electro Static Discharge (ESD), your computer is off, and that you're properly grounding yourself. Especially before removing the battery.
If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. Simply use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation and/or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Enter CMOS values
Once the battery is replaced turn on the computer and enter all values back into CMOS or set the values back to the default settings. Additional information about getting the values back to default can be found on document CH000970.
If after following all the above steps you continue to experience the same error when your computer starts and/or your computer is still unable to keep the stored values it's likely that you're experiencing a more serious issues. Most likely causes are bad power supply or bad motherboard.
May 30, 2010 | Toshiba Satellite A60 Notebook
My computer clock is running fast... I figure it's the CMOS battery because it's almost 5 years old. It's a Compaq Presario SR1503WM Desktop. Which battery should I buy?
just u will remove the Cmos battery from your computers mother board and take it.
go to shop and ask like this battery i need.
then buy and replace it..
thank u sir... All The Best...
Apr 22, 2010 | HP Compaq Presario SR1503wm PC Desktop
How to change cmos battery give me some video or pictures or something like that plz
cmos.gifOpen the computer case and find the battery on the computer motherboard,verify that it will be accessible and that it can be removed. Mostcomputers today use a coin cell CMOS battery as shown in the image tothe right.
If you are unable to locateyour CMOS battery you will need to refer to your motherboard orcomputer documentation and/or contact your computer manufacturer for additional assistance in locating it.
Unfortunately,most manufacturers will not list the exact type and model of your CMOSbattery; therefore, once you have located the battery, write down allinformation about the battery (Voltage, chemistry, wiring, andpackaging). If possible, remove the battery and take it to the locationyou plan on purchasing a new battery from.
Ifyou're computer is using a coin cell battery similar to the aboveexample picture. Removing the battery is relatively simple. Simply useyour fingers to grab on the edge of the battery and pull it up and outof the container holding it. Some motherboards have a clip holding thebattery down. If your computer has this clip you may need to use onehad to move the clip up and the other hand to pull the battery out.
Unfortunately,not all CMOS batteries are removable; some manufactures will only allowa replacement battery to be added. If you're not using a coin cellbattery and are not able to determine how to remove it refer to yourmotherboard or computer documentation and/or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Userswith computers that do not have removable batteries only options toinstall a new battery will most likely also need to set a jumper when adding the new battery into their computer.
Enter CMOS values
Oncethe battery is replaced turn on the computer and enter all values backinto CMOS or set the values back to the default settings.
Mar 08, 2010 | IBM ThinkPad R30 2656 Notebook
I power up shows erros i set the date and time and enter it turns off then comes right back on doing the same thing showing the same errors
hi... u hav to replace the BIOS battery, go to a computer hardware shop and buy 1 and u can replace it by ur on
cmos.gif Obtain battery information
Enter CMOS values
Oncethe battery is replaced turn on the computer and enter all values backinto CMOS or set the values back to the default settings. Additionalinformation about getting the values back to default can be found ondocument CH000970.
After the values have allbeen entered make sure to save the settings before exiting. Many CMOSsetups allow you to press a key (such as F10) to save values and exitall in one action.
Jan 14, 2010 | Computers & Internet
I need to find and replace the CMOS battery in a Compaq Presario 1200
write down the model number or the volt of your CMOS battery and go to any computer hardware shop..
buy the CMOS battery corresponding to your model number or your battery's volt...
all the CMOS battery are almost similar
Dec 19, 2009 | Compaq Presario 1200,1600 (297657-001)...
Low cmos battery
You will have to open the case and look on the motherboard. There is a small battery looks like a watch battery. Just take it out and buy one with the exact amount of voltage. Snap the new one back in and voila done..
Don't forget to rate this solution.
Feb 19, 2009 | E-Machines Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
