Where can I buy the 1000 uf capacitors - Televison & Video
4 Suggested Answers
  • 3 Answers
SOURCE: ILO DVDr05
As long as the voltage rating is higher, not lower, it is fine, actually better, especially since this seems to be a fairly common problem, the capacitors used may not have a high enough rating to survive transients that may occur. As long as you are replacing them, I would use a higher rating, to make it more robust.
Posted on Dec 28, 2008
  • 51 Answers
SOURCE: syncmaster 740 power supply problem
I would check all the transistors (especially the larger ones) for shorts. If you can separate the power supply from the other circuits (such as by unplugging a connector to other boards), I would do this and see if the fuse still blows. If it doesn't, then the trouble is in another area, perhaps the LCD driver circuits.
Posted on Dec 30, 2008
  • 21 Answers
SOURCE: Can i use 35v 1000 uf instead of 25v
NO!
Posted on Dec 11, 2013
I need to know the value of the capacitors at C4 and C5 thank you
Hi there, im assuming you have the ARF 2001 scanning/transceiver.
I found your print and C4 is 1000 and C5 is 1000.
Example: capacitor 101, it is measuerd at micro (uf) and picofrads (pf) therefor this is calculated at 0.001 (uf), 1000 (pf).
The answer to your question is capacitor code for C4 & C5 is 1000.
0.0001 (uf) or 1000 (pf).
I hope this helps.
Feb 09, 2013 | Radio Communications
Stuck in standbye
Check for bad capacitors in power supply; 2200 uf and 1000 uf close to the heat sink of the top of power supply.
Nov 26, 2011 | Samsung 50 in. Plasma TV
Low voltage Error, Citizen CBM 1000 II thermal printer.
check fuse 2 as this would cause the 3 short 1 long flash code. Even if its not blown at least you can trace that part of the crcuit for other blown devices
Aug 02, 2010 | Citizen CBM 1000 thermal Printer
Blinking timer light and cannot turn on
How many times does the LED blink? Does it blink 6 times, pauses, and repeats? Or is it some other number of blinks? Or does it just blink continuously, once a second? (Note: on Mitsubishi's it is normal for the TV to blink rapidly for about 90 seconds after you plug the TV in, while the TV runs internal self-tests.) If the LED continues to blink continuously after 90 seconds, then the problem is on the DM board. There are 4 electrolytic capacitors, grouped together. I believe they are either 820 uF (mfd - microfarads) or 1000 uF at 16 Volts. If you check them, you will see that their tops are swollen (slightly rounded; not flat across). They will check okay with a capacitance meter or ESR meter, but don't believe your meter! Replace those 4 capacitors with either 820 or 1000 uF capacitors rated at either 16 or 25 volts. Make sure you use good, high-temperature (105 deg C) low-ESR capacitors. I recommend the "FM Series" capacitors from Digi-Key corporation, part number P12366-ND or P12379-ND. Less than $1.00 apiece. Good luck!
Dec 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv will not turn on
Common problem with this set are the two 1000uF@25v capacitors and the 150uF@400v cap on the power supply board.
May 12, 2009 | Apex Digital LD1919 19 in. LCD TV
Syncmaster 740 power supply problem
Dec 17, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
ILO DVDr05
Nov 20, 2008 | iLO DVDR05 DVD Recorder
Dm board mit wd52525
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Sep 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Vertical hold?
replaced this capacitors in vertical circuit.100 uf/50v,1uf/50v,1000 uf/25v,2.2uf/50v,47 uf/50v.this might not as exact as what is on ur tv.but, just replace those capacitors and see the result. hope this help u....
May 09, 2007 | Sanyo DS31590 31" TV
The blue light of the monitor keep flash and no picture appears on the screen
I have exactly the same problem with my Medion 17" TFT monitor. It is not the video card (tried changing it) or the motherboard. Fitting a different monitor makes the problem go away. The monitor does not display the "No Signal" message when unplugged from the PC either. It must be a fault in the monitor, and as it seems to be a design fault. I suggest you contact Medion and nag for a replacement.
Dec 06, 2006 | Medion MD 7317 17" Flat Panel LCD Monitor
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
