How do I change Slideshow speed from a USB Stick on a TDE4874B TV
Cannot download music from my computor to my usb stick
The speed of the USB port you are trying to use and the speed of the stick might be an issue. In other words, if the stick is a 2.0, it might not work in a 3.0 USB port, but probably would work in a 2.0 or 1.0 USB port.
Nov 24, 2017 | Video Game Consoles & Games
How to record tv to a usb
The USB write speed is probably not fast enough to record directly from a TV. You should record to yur hard drive then transfer the file to the usb stick.
Jul 03, 2013 | Televison & Video
Eh5000 wont play movies on usb stick
The TV can only play a specific format of video. You may be using MP4 files while the TV can only view 3GP or FLV formats; just try downloading a converter (I've used FLV Converter on Windows XP for years, works fine and very simple) and changing the file format.
Jan 30, 2018 | Samsung Electronics Samsung 40" EH5000...
I have several hundred JPEGs on a thumb drive that I want to play in a continuous loop on the TV through my PlayStation 3. I can get the pictures to display with no problems, but I can't figure out...
plug in your usb device. Now go to photo on your main menu in the ps3, find usb device and hit X, it's going to say digital camera images, now hit the triangle for options, slideshow comes up with start next to it, hit X, then choose what type of slideshow you want(ex: normal, slide, portrait, ect.) hit X and there you go.
Jul 28, 2011 | Televison & Video
I have USB cable attached to tv and DVD player and
Connect the DVD to TV with HDMI or component video, don't use USB, USB on the TV is to insert a flashdrive/thumb drive to display a slideshow or download music.
Good Luck !
Mar 22, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
After slideshow memory stick is missing photos (not on computer)
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
Sep 19, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
