Regsvr32.exe -erreur d'application (0xc0000018)
Keep getting the status code 12152. cannot send emails, cannot delete, and my mail takes a long tine to open up
You might have a virus. Create a batch file with the below details ---------------------- %SystemDrive% cd "\" cls taskkill /im YahooMessenger.exe /f taskkill /im Ymsgr_tray.exe /f taskkill /im yupdater.exe /f rd "%ProgramFiles%\Yahoo!\Messenger\Cache\" /s /q rd "%ProgramFiles%\Yahoo!\Messenger\imvcach... /s /q rd "%ProgramFiles%\Yahoo!\Messenger\logs\" /s /q rd "%ProgramFiles%\Yahoo!\Messenger\Plugin\... /s /q rd "%ProgramFiles(x86)%\Yahoo!\Messenger\Ca... /s /q rd "%ProgramFiles(x86)%\Yahoo!\Messenger\im... /s /q rd "%ProgramFiles(x86)%\Yahoo!\Messenger\lo... /s /q rd "%ProgramFiles(x86)%\Yahoo!\Messenger\Pl... /s /q rd "%AllUsersProfile%\Application Data\Yahoo!\" /s /q rd "%AppData%\Yahoo!\" /s /q rd "%LocalAppData%\Yahoo\" /s /q rd "%ProgramData%\Yahoo!\" /s /q rd "%UserProfile%\Local Settings\Application Data\Yahoo\" /s /q reg delete HKCU\Software\Yahoo /f reg delete HKLM\SOFTWARE\Yahoo /f del "%ProgramFiles%\Yahoo!\Messenger\*-*" /f /s /q del "%ProgramFiles%\Yahoo!\Messenger\*.tmp" /f /s /q del "%ProgramFiles(x86)%\Yahoo!\Messenger\*-... /f /s /q del "%ProgramFiles(x86)%\Yahoo!\Messenger\*.... /f /s /q del "%temp%\*.*" /f /s /q regsvr32 actxprxy.dll /s regsvr32 browseui.dll /s regsvr32 jscript.dll /s regsvr32 mshtml.dll /s regsvr32 msxml.dll /s regsvr32 oleaut32.dll /s regsvr32 shdocvw.dll /s regsvr32 urlmon.dll /s regsvr32 vbscript.dll /s regsvr32 wininet.dll /s exit ------------------ Open the computer registry and navigate to HKEY_CURRENT_USER > Software > Microsoft > Windows > CurrentVersion > Internet Settings > Zones
Zones you should see 5 Zones 0 Computer (not shown in IE by default) 1 Internet 2 Local Intranet 3Trusted Sites 4 Restricted Sites
Delete other entries Restart your Computer
You should be okay now
Jul 15, 2011 | Yahoo Mail
Tip
Remove unwanted startup items to speedup Windows Logon
There are several methods to do this Microsoft's own msconfig.exe goto the run menu and type msconfig, is one that I still tend to favour however Mike Lin's StartupControlPanel work just as well with the added bonus of a recycle bin
MalwareBytes StartUpLite has a list of all unnecessary startups on their website for information only it will tell you which ones you have just remove then if you don't have any in their list you will get the following screen
The one problem that you may have is CTFMON.EXE it will keep returning not matter what it is the Microsoft process that controls Alternative User Input and the Office Language bar. It’s how you can control the computer via speech or a pen tablet, or using the onscreen keyboard inputs for asian languages.
If you really want to disable it unregister the DLL's that control it run these two commands in the start menu run one at a time you will receive confirmation that if has been done in a Regsvr32 window like the one below
Regsvr32.exe /u msimtf.dll
Regsvr32.exe /u msctf.dll
Reboot your computer and then open a Microsoft Office application if you do have that installed. Verify that ctfmon.exe is not running using Process Explorer from Sysinternals the best alternative to the Windows Task Manager.
on Mar 08, 2010 | Microsoft Windows XP Home Edition for PC
What does 0x800ffff mean
KB1001.800
Problem: GWXMail error 0x800FFFF (or other) using REGSVR32
This article applies to GWXmail
Problem
    When you run regsvr32 with GWXMail to register it, you may get error 0x800FFFF or a generic message saying the registration failed.
Details
    Microsoft's REGSVR32.EXE program is used to register all Active X server components. If you don't have the most recent version of regsvr32.exe, or don't have all the correct support files to go with it, you may not be able to register your Active X component.
Solution
    Search your hard drive to make sure you only have one copy of regsvr32.exe. If you have more than one, delete all but the most recent. Check Microsoft's site for a newer regsvr32.exe, especially if you are not using IIS 4.x, or haven't applied the IIS 4.x service pack.
    Make sure you have version 05.00.4319(SP2) of MSVBVM50.DLL on your system. If you need this file, you may download it from here or from Microsoft.
Feb 13, 2011 | Computers & Internet
It says social view plugin is missing. And when i open my messenger and send a message to somebody i dont see anything he is writing to me or anything i am writing to him. I dont know what is the problem....
Make this Yahoo Messenger cache cleaning tool
Hold down the Windows key - Bottom row with flag and press R
Type in notepad and click OK
Copy and paste the following code onto notepad
%SystemDrive%
cd "\"
cls
rd "%ProgramFiles%\Yahoo!\Messenger\imvcache\" /s /q
rd "%ProgramFiles%\Yahoo!\Messenger\Plugin\" /s /q
rd "%ProgramFiles(x86)%\Yahoo!\Messenger\Cache\" /s /q
rd "%ProgramFiles(x86)%\Yahoo!\Messenger\imvcache\" /s /q
rd "%ProgramFiles(x86)%\Yahoo!\Messenger\logs\" /s /q
rd "%ProgramFiles(x86)%\Yahoo!\Messenger\Plugin\" /s /q
del "%ProgramFiles(x86)%\Yahoo!\Messenger\*-*" /f /s /q
del "%ProgramFiles(x86)%\Yahoo!\Messenger\*.tmp" /f /s /q
exit
Save the notepad on your Desktop as .........cache.bat...... the (.) is important between cache and bat.
All being well, you should now have an Icon on your Desktop named cache
Make a System Restore Point
If you have XP double click on the cache icon to run it
If you have Vista or Win 7 right click on it and 'Run as Administrator'
Dec 22, 2010 | Yahoo Messenger
Need to fix svchost.exe the instruction at
I have a fix for it - it's somewhat lengthy, but it works. Follow the directions below to a T and you'll be all set.
Verify Windows Update Service Settings
  • Click on Start, Run and type the following command in the open box and click OK
    services.msc
  • Find the Automatic Updates service and double-click on it.
  • Click on the Log On Tab and make sure the "Local System Account" is selected as the logon account and the box for "allow service to interact with desktop" is UNCHECKED.
  • Under the Hardware Profile section in the Log On Tab, make sure the service is enabled.
  • On the General Tab, the Startup Type should be Automatic, if not, drop the box down and select Automatic.
  • Under "Service Status" on the General tab, the service should be Started, click the Start button enable it.
  • Repeat the steps above for the service "Background Intelligent Transfer Service (BITS)"
Re-Register Windows Update DLLs
  • Click on Start, Run, and type CMD and click ok
  • In the black command window type the following command and press Enter
    REGSVR32 WUAPI.DLL
  • Wait until you receive the "DllRegisterServer in WUAPI.DLL succeeded" message and click OK
  • Repeat the last two steps above for each of the following commands:
    REGSVR32 WUAUENG.DLL
    REGSVR32 WUAUENG1.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUCLTUI.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Remove Corrupted Windows Update Files
  • At the command prompt, type the following command and press Enter
    net stop WuAuServ
  • Still at the command prompt,
    type cd %windir% and press Enter
  • In the opened folder, type the following command and press Enter to rename the SoftwareDistribution Folder
    ren SoftwareDistribution SD_OLD
  • Restart the Windows Update Service by typing the following at the command prompt
    net start WuAuServ
  • type Exit and Press Enter to close the command prompt
Reboot Windows
  • click on Start, Shut Down, and Restart to reboot Windows XP
Although this method may not solve all of the issues with a SVCHOST.EXE Application error, I have found it fixed the problem with the 0x745f2780 reference error.
Hope this helps! Good luck!
Sep 17, 2009 | Dell Microsoft Windows XP Home Edition
This problem details appear when i open gadgets in win 7 plz help
I assume you are using Vista, please try this:
Click Start, All Programs, Accessories, right-click Command Prompt and
select "Run as administrator".
Type these commands one by one exclty as shown below:
Regsvr32 atl.dll
Regsvr32 "%ProgramFiles%\Windows Sidebar\sbdrop.dll"
Regsvr32 "%ProgramFiles%\Windows Sidebar\wlsrvc.dll"
Reboot your computer.
Please rate this solution. thanks and good luck!
Jun 20, 2009 | Computers & Internet
Application Error
How to Repair this SVCHOST.EXE error
After some investigating into the 0X745f2780 SVCHOST error, it became apparent the problem is a corrupted Windows Update in Windows XP. Follow the steps below to fix this error.
    services.msc
    REGSVR32 WUAPI.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Mar 30, 2009 | Microsoft Windows XP Professional
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
Legacy
Please try the following:
Click Start >> Run >>
Type the follow command in the Open box.
"net.exe stop wuauserv" (w/o quotes)
Press Ok
Repeat the same for the following commands:
regsvr32.exe wuapi.dll
regsvr32.exe wups.dll
regsvr32.exe wuaueng.dll
regsvr32.exe wucltui.dll
regsvr32.exe MSXML3.dll
regsvr32.exe qmgr.dll
regsvr32.exe qmgrprxy.dll
net.exe start wuauserv
Restart the machine and try again.
May 01, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
