Question about Bauknecht Dishwashers
Bauknecht 3321 8 blinks code - Bauknecht Dishwashers
my BAUKNECHT WA 709 709 SC washing machine doesn't work what should I do? no one could fix it
Aug 27, 2012 | Washing Machines
Error code F13 Bauknecht washer front loading
error codes washer machine bauknecht f13
Nov 15, 2011 | Washing Machines
Hi, on my WAE8987 Washing machine, the fault code 'F07' keeps coming up, can anyone help please? thanks
Bauknecht are built by Whirlpool.
F7 on Whirlpool means flow meter failure.
Check water inlet, check the pressure switch, and check the sump filter at the bottom of the dishwasher.
To reset try turning on the power and holding the start button and the + and - buttons at the same time.
Dec 01, 2009 | Bauknecht Dishwashers
Maintenance lights won't go away
elaine hopefully this will help. advance your selector dial to the 6 o'clock position, press start 3x. advance your selector dial to 7 o'clock position, press start 3x. turn the unit off then on. try using it as normal.
Apr 24, 2017 | Whirlpool Dryers
Bauknecht washing machine fault
Had the same problem myslef yesterday. Have rung whirlpool this morning and they advise that the code F7 refers to a short circuit.
May 27, 2008 | Washing Machines
Dishwashers Logo
Top Bauknecht Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Andrew Taylor
Andrew Taylor
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
