Question about In Office Equipment & Supplies
Return cartridge stays in right margin and will not return to next line
JUSTOLDJIM
  • 478 Answers
SOURCE: Carriage return problem
Try pressing the margin release key then backspace and reset the left margin.
Posted on Jan 23, 2008
  • 3594 Answers
SOURCE: Wheelwriter 10 Series II
Try a little light oil on the printer shaft. WD40 works well.
DickyO
Posted on May 16, 2008
SOURCE: Automatic RETURN/ENTER ...
I set scanner to defaults and had to Scan Bar Code labeled <DATA><SUFFIX 1> on page 4-50 of LS 2106 Product Reference Guide to set return after scan.
http://www.intermeccorp.com/pdf/2106setup.pdf
Posted on Sep 11, 2008
  • 3594 Answers
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Posted on Dec 08, 2008
JUSTOLDJIM
  • 478 Answers
SOURCE: carriage return problem
The tab button may be stuck or the carriage release lever is stuck or a broken escapement.
Posted on Dec 31, 2008
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
Return to tab
Don't confuse tabs and margins, after a return it always goes to left margin. Use the tab key to go from the left to the next place where you set a tab
Jan 30, 2014 | Nakajima AE-740 Typewriter
Tab and return
reset the left margin at 69, or return and then press tab to start a new line
KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
May 28, 2011 | Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
I have a typewriter accuspell T34
Perhaps the L. margin is se allthe way to the right. Press the margin rel. key and backspace to the L. then press L. margin key. DickyO
Mar 27, 2009 | Office Equipment & Supplies
Return key doesnt work properly
Try putting a little light oil on the silver shaft that the printer slides on, WD40 works well.
DickyO
Dec 09, 2008 | Lexmark Wheelwriter 1000 Typewriter
Installed new toner. Printer prints well, except approx 1 inch of vertical line doesn't print about 1/2 inch from right margin. Have gently shaken cartridge, run a cleaning paper, reiserted cartridge.
Assuming none of your print area margin settings have been changed, it sounds like you may have a defective drum. You can try carefully cleaning the corona wire, a hair thin wire, with a dry cotton swab. Do not touch the drum! The drum is an integral part of the toner cartridge. Return it to the store as defective.
Aug 17, 2008 | HP LaserJet 1022 Printer
Margin Problems
You are in auto return. Press code and R
This should doit
DickyO
Mar 10, 2008 | IBM Wheelwriter 30 Typewriter
21 people viewed this question
Top In Office Equipment & Supplies Experts
Mohul
Mohul
Level 1 Expert
Tygh Duval
Tygh Duval
Jason
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
