Question about The Office Equipment & Supplies
My Dx 2430 copy printer does not work because I have an E-24 code displayed. How do I fix it?
When you switch on the copy printer it displays E-24
informatica
  • 1114 Answers
SOURCE: LED not display time
Depends where you are in the world, try a google search for CR 2430 as below and add your country: http://www.google.co.uk/search?hl=en&q=CR+2430&btnG=Google+Search&meta= Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 31, 2007
  • 2072 Answers
SOURCE: no display on machine..
Sounds like the display backlight has failed. Need to replace the display.
Posted on Aug 15, 2008
  • 81 Answers
SOURCE: hp 2430 printer copies are faint
Try going to the printer properties and change the quality of the output.
Good luck
Posted on Dec 13, 2008
SOURCE: "E" displayed & won't copy when I try to make a black copy
printer ink door is not shut
Posted on Mar 03, 2009
  • 3422 Answers
SOURCE: Canon MP830 error code 6A00
HI,
Please the pixma off and open the lid.Now manually slide the cartridge-tray to the left.
Use a piece of tissue to clean the base-pad where the heads are stored.See if it is stuck in a kind of upward position and look if the mechanism that moves the tray is released if not then touch it and it will be loose. Remove all ink residue, move the tray back to its most right position and close everything.
Let me know if you still get the same error.
Thank you
Posted on Aug 13, 2009
Reset drum
Hi there!
To reset the drum light you need to press the following keys in sequence with 4 seconds for the initial 4 keys
Step 1: You need to press "C" then please press the far left key ( called exposure mode key) then press the "C" key then the far left key once again.
So the sequence is -- C, far left, C, far left.
Note: Some model utilize two other initial codes, you might need to use one of those two alternate codes to get your display to go blank. The remainder of the procedure is absolutely the same.
The alternate codes are as follows: #, * , C, * or pound key ,star key, C, star key and also #, Interrupt key, C, Interrupt key.
If done correctly the display will go blank.
Then type in 24 as if you are going to print 24 copies of something.
Then press the "print" button.
Then type in 7 as if you are making 7 copies
Now press the print button once again.
You will now get flashing zero's on the display of the unit.
Turn the machine off and then on again and your drum light will be gone.
Sep 06, 2010 | Sharp AL-1651CS All-In-One Laser Printer
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
MY toshiba satellite 2430 CAN NOT POWER UP. BUT IT ALL THE LIGHT IS ON WHEN I SWITCH ON THE DC POWER SUPPLY SWITCH. WHAT IS THE PROBLEM? HELP.
remove the battery and remove the power adaptor ... press and hold the power button in the ON position and count to 20.
attach the AC adaptor only and press the power button ...this should fix the issue ... then re connect the battery.
if this does not work then add a external monitor .. if it lights up then hit the
Fn + F5 keys
Display modes
Fn + This hot key cycles through the power-on
display mode options.
The display mode options are:
Built-in display panel only, Built-in display panel and
external monitor simultaneously, External monitor only.
Fn + This hot key cycles through the power-on display options.
The display modes are:
❖ Built-in display panel only
❖ Built-in display panel and external
❖ External monitor only
video device simultaneously
❖ External video device only
Oct 07, 2009 | Toshiba Satellite 2430 Notebook
How do you restart a Sharp AL 1631 After replacing the drum
press C - Auto - C - Auto the display will go off . Enter 24 press Print press 7 press Print . It will display 00. Off and On.
Jul 01, 2009 | Sharp AL 1631 Copier
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
Minolta 2430dl has no display
check display wires connected to pwb
Jul 25, 2008 | Minolta 2430DL Color Laser Printer
Service Code
TRY CLOSE ALL THE COVER PROPERLY
Mar 18, 2008 | Office Equipment & Supplies
27 people viewed this question
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
