Question about Golf
YAMAHA G9 WON'T SHUT OFF WE PULLED THE BATTERY CABLE OFF IT STILL RAN FOR 3 HOURS UNTIL IT RAN OUT OF GAS
  • 71 Answers
Look for a bad ground connection. As a temporary shutoff, pull the spark plug wire off.
Posted on Jul 03, 2017
SOURCE: My sons 1990 626 ran
My car was running fine, stalled in traffic once, restarted it without a problem, drove a few more miles and it just died - wouldn't start, still had lights though. Sat for a few hours, had it towed to my mechanic, he got in and it started up, right away. Drove it off his lot, ran some errands, few hours later it just died again, had it towed back to the mechanic - he put in new coil, did a tune up, picked it up, still having problems with it, got it home, next morning going to work, it died again, towed it back to the mechanic, he still has it - very frustrating. Any suggestions? This is a 1990 626 Mazda
Posted on Dec 07, 2008
SOURCE: Canon G9 - image disappears
If you go to display and click down to "review" you should be able to set the review time to what you would like. The default may be 102 seonds. This should work and check the manual
Posted on Jan 13, 2009
  • 93 Answers
SOURCE: cooling fans
Yes, if the sensor didn't fix it, it is probably a relay problem. Chrysler has a habit (my truck especially) of using underrated relays that fuse in the closed position.
Power from the battery goes to the relay directly and that's the only place that the circuit would be opened to turn off the fans.
Posted on May 07, 2009
  • 69 Answers
SOURCE: jaguar s type, helper jump cabled my car and
You´ll need a new batt and a scanner reset, but maybe if (-) batt pole wasn´t properly touched you have a serious module damage! Good Luck!
Posted on Dec 18, 2010
  • 2925 Answers
SOURCE: sat for 3 years running when we stopped driving now it wont restart. chkd fuses, relays, b
Fuel is probably stale. Pump or pump relay might be stuck.
I suggest you check the fuel delivery to the fuel rail. If no delivery the pump isn't working and the supply should be checked and then take the appropriate action depending whether the supply is good or not.
Posted on May 30, 2016
Yamaha g9 gas golf cart won't shut off we pulled the battery cable off and it still ran for 3 hours until it ran out of gas
Check the throttle cable on the carb to see if it is returning to off position. There also may be a stop switch in the floorboard that grounds the engine when the pedal is in the up position.
May 17, 2017 | Golf
2004 yamaha yz250f ran all weekend then the next day after riding it, it wouldn't start
Hi, Alex and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Bike won start just backfires occasionally
Dirt Rider Magazine
YAMAHA YZ250F Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 24, 2013 | 2004 Yamaha YZ 250 F
My 82 yamaha xj 650 maxim turns over but wont start. it sounds like there is no gas getting to the engine . I put premium gas in . looks like the fuel filter hose is not clamped. and there is a slight
Hi, Shawn and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2, TPS, ETP, IAC,or BAS).
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box if applicable.
17. Tilt sensor needs a reset.
18. Security system not disarming alarm needs a reset.
80 Yamaha Maxim 650 Won Start
81 yamaha xj650 maxim turns over after top end rebuild but doesn ignite...
Yamaha XJ750 Owners Workshop Manual
http://www.carlsalter.com/pdfs/Yamaha_XJ600SK_Owners_Manual.pdf
Sep 15, 2012 | 1982 Yamaha XJ 650
2003 Chrysler town & country limited
First try and change the fuel filter. this also happened on a van i worked on. I cahnged the filter and it runs fine now.
Nov 16, 2011 | 2003 Chrysler Town & Country
I have an 03 yz125 that ran perfectly and started instantly on the first kick, until this evening. It was ridden yesterday with no problems. However, this afternoon, the bike would not start AT ALL. I...
Hi, Gregore_z28 and the usual suspects are:
1. Fuel tank empty.
yz 125 wont start
Dirt Rider Magazine
YAMAHA YZ125 Owner Service Manual
Aug 18, 2011 | 2003 Yamaha YZ 125
Just purchased a 2001 Yamaha YZ125..ran fine for few hours then quit running while riding,now won't start..appreciate any help !!!
Hi, John316371 and the usual suspects are:
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. A failed fuel pump, pressure regulator and or fuel injectors.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
yz 125 wont start
Dirt Rider Magazine
Jul 28, 2011 | Yamaha YZ 125 Motorcycles
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
Jan 11, 2009 | Canon PowerShot G9 Digital Camera
My sons 1990 626 ran great. I change the oil and reconnected the speedometer cable that had vibrated loose. took it for a drive to make sure I didn't have any oil leaks. It ran for about 5 minutes and just...
we'll assume fuel is good..leaving spark and air..and management of systems(computer /sensors)...so the speedo cable was disconnected? try taking it loose again , test drive and report back please
Nov 20, 2008 | Mazda 626 Cars & Trucks
Golf Logo
309 people viewed this question
Top Golf Experts
Ronald Prier
Tom Chichester
Bill Boyd
Are you a Golf Expert? Answer questions, earn points and help others
