Question about Refrigerators
42TX_060_321CRE this model no. fcu carrir i was ask who is freon in side
Carrier FCU A.C thermostate E4 error coming PlZZ tell me what solution??
Do you have a model number for the equipment in question?
Aug 04, 2016 | Carrier Heating & Cooling
Ac relay looses power in 15 seconds after I turn
Likely you are low on freon in the ac system and low pressure sensor on the compressor feed line is cutting out the ac system. Then pressure rises enough for it to turn on and it cycles again.
Oct 12, 2014 | Cars & Trucks
We are not able to receive or fax out, connection line is good. Just stop working
If you cannot hear a dial tone on the copier, the modem on the copier may need replacing. It maybe part of the FCU PCB depending on the model.
Aug 19, 2014 | Cannon Office Equipment & Supplies
What do these codes mean and how do I fix them? sc819 and sc820 I have a Gestetner dsm618d Thank you!
Install a new firmware, or
When installing the FCU, slowly and carefully connect the MBU to the FCU to
ensure a proper connection.
! If the connection is not properly established, the fax option may not be detected
and/or SC820 may occur.
Jun 14, 2011 | Gestetner DSm618d Copier
How many psi of freon does your 1995 honda accord lx need
People, he asked for the psi, not how to do it and everything else. High side, 35-50 psi. Low side 20-35 psi. Very simple question to answer. He likely knows how to do it, just needs the psi for high and low.
Mar 02, 2010 | 1992 Honda Accord
A/c compressor not working added freon but it
Either the system is still low of freon,or the sensor (one of them)is bad.The sensors are on the high side of the system,liquid line.If you will get on chat,I can help you with this,it will take a while,I will need to know how much freon was added.And what the system is doing,is the ac clutch engaging,etc?Ask for ronicon,when you click on chat with,type my name in,roniecon,with your text,that you are writing .
Jan 19, 2010 | 1998 Cadillac Eldorado
The ac will temporarily blow hot air on the drivers side, but remains cold on the passenger side. any advice?
this is a sign that the a/c system might be low on freon. I would have it recharged. Asked the tech to add dye during the recharge that way if the system gets low on freon he'll be able to use ans specail black light to look for the freon leak.
Jul 08, 2009 | 2001 Pontiac Grand Prix
Ricoh Aficio 1515MF erra say ing phone no for service,cant get re
define your question better please, it is possible for the FCU on this model to hang, requiring a FCU memory reset through the sp mode.
Mar 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Samsung split system air conditioner model as24bpa
Suction-5/8"
Liq. line-1/4"
Max pipe length-50'
Max vertical hight bet. accu and fcu-25'
Jan 06, 2008 | Samsung AS18A6RB Air Conditioner
Error code 0-09
Hi there I can only find in the service manual 6-09 and 9-09 I will attach the reasons for both if they are of any help great if not there are no tech bulletins for this machine that says otherwise.
Thanks J
9-09 Paper jam in the fusing exit
area
If the problem persists, replace the FCU.
6-09 G3 ECM - ERR received Check for a noisy line.
Adjust the Tx levels of the communicating
machines.
See code 6-05.
6-05 G3 ECM - facsimile data
frame not received within
18 s of CFR, but there was
no line fail
Check the line connection.
Check connections from the NCU to the FCU.
Check for a bad line or defective remote terminal.
Replace the FCU, FCU or NCU.
Try adjusting the rx cable equalizer
Cross reference
Rx cable equalizer - G3 Switch 07 (PSTN), G3
Switch 08 (PABX)
Jan 04, 2008 | Ricoh FAX5000L Plain Paper Laser
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
