High and low population density between low and high income areas
PcExpert
  • 293 Answers
SOURCE: ga-8ipe1000 does it support high density memmory?
No Non ECC Only
Posted on Sep 18, 2007
  • 17 Answers
SOURCE: emachine w3118 memory
while the reason you want to know density might help to answer, if you are buying memory you only need to know it will work in your machine
when I bought memory for my computer I googled brand and model number with the word "memory" and found a seller that had a little tool I down loaded and ran to tell me what memory was needed
memory is very cheap now days so price compare before you buy
Posted on Feb 25, 2008
knotbeerdan
  • 413 Answers
SOURCE: How do I determine what kind of memory that I need?
in order to know what kind of memory you need you will have to look up the model of the computer and hopefully that is it. High density is manufacturer specific and it is very important if you order hi density for the wrong brand it wont work. My educated guess is you will want low density 266mhz and depending on how new you might only be able to upgrade 256 mb per stick I hope this helps i know its a confusing subject but really you just need to get online and start researching ram before you make any decisions.
Posted on Dec 30, 2008
wayneard
  • 1901 Answers
SOURCE: does ASUS P4P800 deluxe support high density memories
Here is a link to Asus' Qualified Vendor List of RAM modules for your motherboard. I do not see it mention high density RAM. You would need to search the specs on the modules recommended to be sure.
ASUS QVL
In case you don't have the manual, here is a link for it too:
ASUS P4P800 Deluxe Manual
Memory info begins on Page 2-10. Again, there is no mantion of HD modules.
Posted on Mar 02, 2009
support793
  • 81 Answers
SOURCE: Does GA-8I945P motherboard support high density memory?
You have 4 slots available. Each slot can take a 1gb non ecc memory module with the specs below.
4 DDR II DIMM memory slots (supports up to 4GB memory)
Supports 1.8V DDR II DIMM
Supports dual channel DDR II 667/533/400 DIMM
Posted on Mar 22, 2009
Define the parts of desity
Density ' Define Density at Dictionary.com
www.dictionary.com/browse/density
  1. Cached
Density definition, the state or quality of being dense; compactness; closely set or ... is upon us, driven in large part by the returns to density, skills, and creativity.
Population density ' Define Population density at Dictionary.com
www.dictionary.com/browse/population-density
  1. Cached
Population density definition at Dictionary.com, a free online dictionary with pronunciation, synonyms and translation. Look it up now!
What is material density? - Definition from WhatIs.com
whatis.techtarget.com > Topics > Computer Science > IT standards and organizations
  1. Cached
  2. Similar
Material density, more often referred to simply as density, is a quantitative expression of the amount of mass contained per unit volume.
Jan 24, 2017 | The Computers & Internet
Population data of bojanala district
Area. • Total, 18,333 km2 (7,078 sq mi).
Population (2011). • Total, 1,507,505.
Density, 82/km2 (210/sq mi).
Jul 29, 2016 | Office Equipment & Supplies
What are rural areas
A rural area is an open swath of land that has few homes or other buildings, and not very many people.
A rural areas population density is very low.
Many people live in a city, or urban area. Their homes and businesses are located very close to one another.
Feb 13, 2014 | CARNI FUEL DEFINITION 8 FL OZ 250 Softgels
Pc ddr memory what is the difference between high density and low density
you need to check with board to fine what ram works with first.i use what they say to use so no problems later and save money as well ok jim
Nov 25, 2011 | Computers & Internet
Hi, I don't know if I should get single or double sided ram for this mother board, and is low density ram ok? Thanks, Wayne
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Thanks.
Oct 31, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
Planning to upgrade my RAM(motherboard K7SOM + V7.5C). Ram have high & low density. What is the difference? Which suit my motherboard? Thanks.
Look at the sticks of RAM -- "high" density means fewer chips on each side of the stick, i.e., newer technology and production methods have packed more bits into each chip, while "low" density usually means 8 chips/side, using older RAM chips.
Older motherboards do not expect to find "high" density RAM, and typically will only detect 1/4 or 1/2 of the RAM on the stick.
If you buy a new motherboard, it will support BOTH densities.
Oct 22, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
ECS 648FX-A1 can it use high density memory?
The Motherboard limitation are DDR400 = 2GB maximum size per slot
Allthough you can with slower memory DDR333 or DDR266 go to the 3GB memory limit.
Due to the age it will be trail and error on the memory types. You won't necessary get any problems with the high density memory as long as it is good quality memory and you don't exceed the slot memory limit as mentioned above.
I recommend that you download the motherboard manual and read it.
Dec 02, 2017 | EliteGroup 648FX-A Motherboard
Emachines T2240
low density works alot more often then high density, HD is just cheaper and thats mostly why it't not compatible with as many boards.
Good luck,
Lee
Jun 11, 2008 | E-Machines T2240 PC Desktop
Memory Stick Installation
So it seems you got the DDR / DDR2 side of the equation correct, but unknown to most, there is 'low' and 'high' density memory.
The density of memory refers to the number of chips used to make the total amount of memory that your memory stick contains. e.g. High density memory has few, large capacity chips to make up the 1024MB of memory on the stick, whereas low density memory uses many, small capacity chips to make up the same 1024MB total on the stick.
Typically, if it is a low / high density conflict, it is the 'low density' sticks only that will boot.
Me, I purchase Kingston memory when I'm unsure what the motherboard will be, and it has never failed to work.
I fix computers.
May 19, 2008 | EliteGroup PM800M2 Motherboard
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
