Question about The Computers & Internet
The diagnostic screen on my mondeo is blank had it checked and all is fine what else could cause this
I have a Mondeo titanium 2010 with a Blaupunkt sat Nav SD card version. the screen suddenly went blank, not only leaving me with no sat nav but also no control over heater, air con, no radio volume. the...
Search finds little on your problem which is odd. I think you need a visit to the Dealership. when was it last serviced? Book it in for service and and ask them to look at that at the same time. You will get a better price and value for money.
Mondeo titanium 2010 Blaupunkt sat Nav SD card version the screen suddenly...
Nov 19, 2017 | Blaupunkt GPS
Touch screen doesn t work
The touch screen connects to a control board. Regardless of what the diagnostics indicate, the control board may be defective.
Jan 16, 2014 | GE Dryers
Blank screen
Check keyboard for 'F' keys which relate to screen Functions. Look for brightness UP or DOWN keys and if nothing else works hold down POWER button until it shuts down. Then push button and allow it to start up again. It will run through self-diagnostic testing and will ask if you want to run computer in Safe or Other Modes-pick Normal Mode.
Very often this will fix the problem.
Sep 15, 2012 | Packard Bell NX.BWTEK.002 EasyNote TS 15.6...
Mondeo tdci turns over but wont start
my ford mondeo zetct turns over but wont fire sparks are fine petrol fine leads are fine new battery new coil what next ecu checked cam sencor checked
Apr 04, 2012 | 2003 Ford Mondeo
Blank screen, error code;0f00c.
The error you appear to be getting during diagnostics should not be related to the computer not starting. The error you are referencing has to do with a blank CD not being in the CD/DVD drive during that part of the test.
I ran the diagnostics again with a blank cd in the drive and I recieved error code 1000-0146.
Mar 12, 2010 | Dell Dimension 3000 PC Desktop
Won't fully boot. Get windows screen, then it stalls gray
reformated twice? have you already ran diagnostics on the hdd? check first the hdd thru diagnostics it might the hdd causing the problem. if no errors found in hdd make sure it was reformated as clean install. your hdd might have partition and just reinstalled OS on he same partition without deleting partitions. Try deleting partitions then create new partitions then reinstall OS.
Oct 21, 2009 | Dell Latitude D610 Notebook
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Mondeo tdci
hi there, you will need a diagnostic check carried out to locate the exact fault, most garages have the equipment to carry out these checks so you won't need to visit your ford agent, a common fault on the engines is the camshaft sensor these cost around £20 and are very easy to replace, however once you have it tested you will now your exact fault, hope this helps
Oct 23, 2008 | 2000 Ford Focus
Blank screen with cycling colours (no BIOS; no POST)
Try running diagnostics. Tap F12 repeatedly on the dell logo till you get the boot device menu. Choose diagnostics. Go through it.
If it doesnt even pull up the diagnostics, you can follow this walkthrough from dell's website.
Oct 04, 2008 | Dell Precision M60 Notebook
GEARBOX DIAGNOSTIC CODES FOR FORD MONDEO AUTO 2002
all eobd codes starting with p zero have standard meanings irespective of model or make
PO12 CODE CAMSHAFT POSITION (cmp) intake/front,bank 1 timing over ******
possible cause valve timing engine macanical fault cmp acutator
POO36 CODE HEATED OXGEN SENSOR HO2S)2BANK 1, HEATER
CAUSE FAULTY SENSOR WIREING SHORTING TO EARTH EC
PO59 HEATED OXGEN SENSOR (HO2S) BANK 2, HEATER RESISTANCE
WIREING HO2S
THESE FAULT CODES HAVE BEEN OBTAINED FROM AN AUTO DATA DISC
I HOPE THIS IS OF SOME HELP TRY CLEARING THE CODES AND SEE IF THEY RE APEAR
IF THEY DO THE SENSORS AND WIRING NEED CHECKING
Aug 22, 2008 | 2001 Ford Focus
Computers & Internet Logo
20 people viewed this question
Top The Computers & Internet Experts
Ed Watson
Level 1 Expert
Alex Krenvalk
Alex Krenvalk
mukhtar21 shaikh
mukhtar21 shaikh
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
