Question about Samsung Microwave Ovens
Why won't Samsung OTR microwave work?
Samsung microwave model ME21F606MJT, purchased 1/2015. No power at all. have checked my wall outlet for power. power good in wall outlet. I went to use oven, absolutely no power, had previously used and it worked great...also check master breakers
    New Friend:
Thanks a lot for informative reply everyone! worked well for me, sharing it with http://dissertationwritingservices.org/ now!
Posted on May 18, 2017
Got swan sm2060R microwave. Plugged it in clock is set but no functions working
test the power outlet plug some lamp desk if work is o.k if NOT reset the c. breaker. follow this stepFirst check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 04, 2013 | Microwave Ovens
Microwave does not work - indicator light says SE
Contact Samsung. I have an OTR Microwave that I purchased in September 2010, which is now out of warranty, I am having the same issue with the error code SE so I called Samsung and they are going to replace my control panel free of charge under there epidemic warranty.
Mar 25, 2013 | Microwave Ovens
Won't run
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Test the switchs door see diagram
Oct 10, 2012 | Frigidaire FMV156DC Microwave Oven
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Replaced the fuse and it immediately blows. My wife cooked several large potatoes got it ral hot before failure
see the steps and eliminate short circuit use the common sense: God bless you
However if after replace the fuse the problem remain, you must test: a) power cord for short b) outlet wall for ground improperly c) HV transformer faulty d) Rectifier HV faulty e) Magnetron faulty. d) power supply faulty replace or repair filter diode, resistor. etc Or call some experimented service tech for troubleshooting.
Jul 27, 2012 | Sharp R-820B Convection/Microwave Oven
My 4yr old NN-S262SF OTR runs for 2secs and stops whenever start
Hello
Microwaves use alot of power and should be on their own 20amp circuit. Get an electrician to put the microwave on its own circuit.
John
Nov 25, 2009 | Panasonic NN-S262SF Microwave Oven
Hi I'm thinking of getting an OTR mictowave and was wondering if I have to install an outlet in the cabinets or can I just place it where the existing wires for the hood fan are. This location would be...
The outlet needs to be in the cabinet above. The microwave needs a dedicated circuit. Turn the power off to the hood and see if any lights or outlets go off on the same curcuit. If only the hood is on that line your good to go with that wire if it meets requirments. Our code asks for 15 amp breaker and 12/2 grounded wire. If it meets your local requirments, just take it up inside the wall to your new outlet location(usually there is enough wire to reach) and install a box, outlet and cover.
Jul 23, 2009 | Microwave Ovens
Samsung otr microwave vent quit working
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Samsung-authorized service center here.
Jul 20, 2009 | Samsung 1.8 Cu. Ft. Over-the-Range...
OTR Amana microwave- No power, lights, clock or sounds.
Either your magnetron, cooling fan, or the magnetron thermostat is failing.
Amana / Whirlpool customer service is here.
Please contact them to find your nearest authorized service center.
Jun 06, 2009 | Amana Radarange Microwave Oven
Microwave Ovens Logo
420 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
