Question about Frigidaire Refrigerators
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
SOURCE: Frigidaire fridge side by side not cooling after cleaning fan
Sounds like you have a bad compressor
Posted on Apr 25, 2009
SOURCE: My freezer keeps icing up and my fridge won't get cool
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement. Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect. If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply. Thank you.
Posted on Apr 29, 2009
SOURCE: freezer freezing and refrigerator not cooling
When it build up ice in the freezer the cold air can't go through to the fridge , this could be because : the fan doesn't work. the unit is low in refrigerant or the defrost timer or heater are bad , if the fan works take off the back pannel inside the freezer and if is only cover with ice part of it and the rest of the coil is clear of ice ,it means that is low on refrigerant (it is a seal system so there's a leak and has to be repair and recharged with freon), but if the coil is all cover with ice the problem is with the defrost system(timer or heaters) you can check the heaters for continuity if open replaced it if ok replace the timer.
Posted on Aug 08, 2009
Feb 03, 2016 | Frigidaire Refrigerators
Aug 17, 2014 | Frigidaire Refrigerators
Sep 23, 2009 | Frigidaire FRS26R4A Side by Side...
May 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Mar 17, 2009 | Frigidaire Refrigerators
Mar 01, 2009 | Frigidaire FSC23F7D Side by Side...
May 25, 2008 | Refrigerators
Dec 09, 2007 | Frigidaire Refrigerators
Dec 02, 2007 | Refrigerators
Sep 05, 2007 | Frigidaire FRT17G4B Top Freezer...
Apr 23, 2018 | Frigidaire Refrigerators
