Just performed the same task on another brand table saw. un-sungged the bolts holding the table to the saw frame and tapped corners of the table while measuring distance from the mitre slot to the lead and tail of the fully extended saw blade (not from the teeth) calibrated to a perfect 90 degrees position. I figured out how to use a digital miter gauge to measure the distance from the blade to the edge of the mitre slot. You can tap appropriate corners to align.
Note when you are in alignment, re-tighten the bolts a little at a time, measuring and tapping as you go.
