Question about Singer Sewing Machines
I have a Singer Athena 2000. While winding the bobbin, the machine light went out. The machine will only sew straight stitch. I pushed the reset button but no change.
All operational light also went out. The straight stitch was the last stitch selected. I can also wind a bobbin but no other functions. What has caused this problem and what needs to be done to repair this?
4 Suggested Answers
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
SOURCE: my singer athena 2000 won't
Yes, the hook timing is off. You need to either take it to a service repair center, or do the timing yourself. If you're mechanically inclined, go to youtube and look for a video by Nilsandkatrina about how to repair your sewing machine. He gives a very good example.
Posted on Nov 29, 2011
  • 1181 Answers
SOURCE: i have athena 2000 electronic sewing machine it seems to be one that winds the bobbin inside the machine but cant get it to rewind the bobbin
SINGER ATHENA 2000 Instruction Manual
http://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Posted on Apr 06, 2015
Athena 2000 won't wind bobbin. Needle goes up and down, but won't catch in bobbin
If you are unable to wind bobbins on your machine, for ~$25 you can purchase a stand-alone bobbin winder at the local fabric store (JoAnns or Hancocks) or online (Amazon.com).
Nov 08, 2015 | Sewing Machines
How do i thread the bobbin on a singer athena 1200 sewing machine
The Athena 1200 and 2000 are "Touch and Sew" slant needle machines. Singer has not made them for many years, but I always loved them, because the bobbin is wound in place--you don't take it out! You can still get a full assortment of presser feet for them; just make sure they're for slant needle machines.
You would be wise to visit the Singer Sewing Machine site and download your user's manual--it's free, and it will show you how to wind the bobbin. There are a series of pictures there as well. There are several steps you need to take, such as raising the presser foot, selecting the blind hem stitch, etc. Sounds complicated, but I owned an Athena 1200, and I can tell you that after the first or second try, you'll find it quite easy.
Incidentally, did you know that it's one of those rare machines that will do a TRUE 1/2" basting stitch! I kept it for years, just for that ability!
Feb 20, 2015 | Singer Sewing Machines
Winding bobbin athena 2000
I had one of these machines, they're Touch and Sew, and the bobbin winds in place. Check to make sure you actually have the correct bobbin inserted, because the bobbin it uses is available with a metal center post and without a center post, and yours takes the one without. I had another machine that took the center post one and accidentally put the wrong one in the 2000 one day and had the same problem.
Jul 10, 2014 | Singer Sewing Machines
Diretions for resetiing Singer Athena TIMING
I have a very similar problem. Low bobbin tension. I cannot adjust the top thread above 3 and have had this thing in to be tuned up a couple times with this problem. It's very irritating.
Mar 17, 2012 | Sewing Machines
How to wind the bobbin on the singer creative touch 1030
on touch and sew models thread the machine up as normal, select straight stitch, presser foot up, take the thread from the needle and wind it round the presser foot screw a few times, open the slide plate, push the little button over, press gently on the foot control to wind the bobbin, when finished close the slide plate to drop the winder down and pull the threads to the back and start sewing
Sep 04, 2011 | Singer Sewing Machines
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
My singer athena 2000 won't pull the bottom thread up to form a stitch. I know this is an OLD machine and I couldn't find the right selection from the list My Singer Athena 2000 sewing machine was...
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
Aug 28, 2008 | Sewing Machines
Singer 7442 will not sew
Had the same problem as mommyb2 - it was the bobbin spindel was in the wrong position. Push bobbin spindel to the left and it works for sewing.
Have the same problem winding my first bobbin - pushed spindel to the right to engage bobbin fuction and the machine locks up and wont wind the bobbin. Irig did you bring it in for repair? I'm thinking its broke - which **** as mine is a brand new machine
Mar 23, 2008 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
