Question about Garden
The pedal is stuck that raises my deck on x304 jd . My deck won't raise up or down how to fix it
  • 195 Answers
SOURCE: mower deck is stuck in down (mowing) position
Hve you tried a "rust remover spray such as wd40,spray and lighty tap until operational. Please rate jj505
Posted on Apr 06, 2009
  • 104 Answers
SOURCE: I cannot raise my passenger electric window in my Polo hatchback
Carefully remove the window switch, open it and spray electrical contact cleaner on contacts. Try it now. You may need to remove door panel and lubricate guides and tracks for window. Let me know.
Posted on Jun 14, 2009
  • 97 Answers
SOURCE: The highest deck setting cuts my grass down to one inch.
leveling bolts hang from each side deck by frame...tightened up and level...will give you some more sure the blades are not bent.
  • 8619 Answers
SOURCE: Driver side window won't raise up!
Thanks for using FixYa. To resolve the issue you are facing with push the unlock button once on the factory remote=unlock all 4 doors. Hit unlock a second time=all four windows down. When exiting vehicle hit the lock button on remote=all 4 windows all the way up. Also, all four window controls on the driver’s door panel are one touch up and down on master window switch. Remove the door panel by prying it off. But be careful not to damage the panel. Now unscrew the top of the panel and the area by the arm rest. Once you get the panel off, then you will see how the switch is mounted into the door panel from inside. If the switch has gone bad this is required to be replaced. Remove the old switch and connect the new one.
Please do rate the solution and revert for further assistance.
Posted on Aug 09, 2009
  • 462 Answers
SOURCE: The front passenger side window on my 1997 Nissan
Sound like a window switch.
If you didn't hear any mechanical noises from window before it happened , most likly - switch.If noises were present , might be window regulator or a motor.
Posted on Apr 16, 2010
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
Why can't I raise or lower the deck?
Sounds like you have jammed linkages which raise and lower deck, you can try this which usually works best with assistant.
With engine off, shake the deck vigorously (up,down, back and forth) while try to raise deck with lever.
Check for worn or damaged arms, springs, deck mounting points, etc and repair or replace.
Sep 01, 2014 | Garden
Craftsman tractor mower deck doesn't go up or down
Make sure lift lever is connected properly and adjusted.
Jun 30, 2014 | Craftsman 26 Hp 54" Deck Yard Tractor
First thing is to get down and look at the linkages. You may have a weld that came loose, or a nut that worked it's way off. You may also have something that bent.
Does the lever move all the way up but the deck doesn't move with it, or does the lever stick at the low level.
If it's sticking, you may just have picked up an obstruction like a stick or stone in the wrong place. You may also have a bent or damaged linkage.
Does one side or just the front or back lift up? One of the pins that hold the bars that it pivots on may have come off or broken as well. Looking underneath while someone works the lever for you can tell you a lot.
Sep 21, 2012 | Garden
JD LT 133 removing 38"
Raise the mower off the floor then put the deck down on it's lowest settings. Hope that works.
Oct 18, 2017 | Sport & Outdoor - Others
Level 5 on the deck height is where I would want 3 to be. How do I raise the deck? I tried the front screw which just raises the front. The 3 holes on the rear end of the deck don't make any differnece...
look under the mower like down below the seat , there should be a bolt on one or both sides ,this is for the back of the mower deac. If not ,raise the deck all the wau up and adjust by th front bolt
May 26, 2010 | Troy-Bilt Pony Garden Tiller
The deck will not raise even , the riding lawnmower is a MTD Yard Machines, and when you raise the deck the left side does as it should, but the right side stays lowered to the ground and will not raise....
There is a pin that has come out of it's holf from the right side of the deck. Have someone raise the deck up and down and you should see a bracket or rod moving up and down. This attaches to the deck with a clevis pin to hold it in place.
Good Day.
Oct 27, 2009 | Mtd Products Yard Machines 158CC Tiller
Craftsman deck raise lever plunger button
Stick it in the end of the handle and screw it down. It threads onto the 'spring'.
Jun 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
