Question about Refrigerators
About Temp setting control .. is # 4 setting fine ?
NO HEAT. A/C works fine. Air blows but no warmth. blows cold air for front defog and cold air blows when temp cranked high 1-5
warmth comes from the heater in the car
if it is climate control check the climate control module
check for heater control in the vent settings as the hot water tap may not be turning on
Sep 20, 2015 | Pontiac Grand Prix Cars & Trucks
Jandy PDA not showing water temp
sounds like a loose wire on the red 4 pin connector to get water temp filter pump must be running lost of times closing crews disconnect that stuff if that doesnt work give me more info
Mar 02, 2013 | Jandy Aqualink Pda P8 Wireless Pool or Spa...
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
Samsung RS267LBRS 4 yr old - Fridge suddenly stopped cooling freezer working fine. Took off back panel - fan runs fine and the coils are not iced. Help!
Make sure the temp settings are on the recommended settings. If they are than the freezer control arm is probably stuck in the shut position or the vent is plugged with ice. you can re secure Arm or defrost the port.
May 05, 2011 | Refrigerators
The temp setting is on 4 for both the freezer and refrig. Which way do we set the temp controls to warm up the temp? Is the lower setting warm or cold?
Good day,
The higher the number the colder the temp. 1 being the warmest.
It takes 12 to 24 hours to realize a new setting's effect. Go slow.
Apr 26, 2010 | Whirlpool Refrigerators
Temp display (fresh food temp) has flashing # 4. Any idea's? Mod# GLHS36EFSB1 - side by side fridge
my Frigidaire showed the number 4 on the display after power outrage. And the temp is really warm inside. I unplug the power and plug it back 1 minute after. now I can set the temperature and it's working fine.
Mar 26, 2010 | Frigidaire GLHS36EESB Side by Side...
U-Line Under counter refer would not cool
it comes set from factory.might void any kind of warrany..if its workin fine on need to recalibrate. you really dont want to mess with it.
Aug 26, 2009 | Refrigerators
Frig mdl#pbb1951grq freezer works fine frig will not cool.
The damper is not opened and closed just by control movement alone. Your control connects to the damper by a notched plastic band. The damper also has a temperature sensor on it. To check damper operation set control to 4. Hold an ice cube to the temp sensor (a coil of small aluminum tubing) and the damper sholud close. As long as the fresh food comprtment is calling for cold air, the damper will remain open reguardless of control setting.
Jun 05, 2009 | Refrigerators
Kitchenaid freezer will not stay frozen 5 years old
it might be your thermostat stucking up...the one your adjusting one notch higher...
Mar 28, 2008 | Refrigerators
Won't maintain a constant temp. Varies from +10 to -15
i doubt that.def sounds like bad cold control though,good news if your producing cold. Hair dryer good---- Ice Pick no good!!!
Feb 18, 2008 | Frigidaire 13 cu. ft. / 368 liter Chest...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
