Question about Ovens Ovens
The fan in my Lamona bottom oven no longer works.Am unsure the top oven is up to temperature.Both ovens indicate reaching temperature quickly after switching on. Advice please. Thanks .Kerry Meaden.
  • 27 Answers
SOURCE: bottom oven not working
If its brand new, most possibly the electrician did not bridge the mains connection. It sounds like an installation fault. There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection. Oshie
Posted on Jun 26, 2007
SOURCE: Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Posted on Apr 17, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 1214 Answers
    A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
    If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
    A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
    Posted on Jan 14, 2009
    • 3463 Answers
    SOURCE: AEG Competence D2160-1m2 (double oven)
    You neede to replace the oven element.
    This is located at the rear of the oven compartment behind a removeable cover.
    Posted on Feb 24, 2010
    Hi I have a 4year old Lamona 4601 double oven, the top oven/grill works fine but when I turn on fan oven it trips the power on the main house fuse board.
    When the main breaker trips it indicates current is escaping from the circuit to ground.
    If it is a micro-circuit breaker that trips it indicates the circuit is consuming too much current - a short circuit.
    Either way the wiring or the oven elements have a fault and need attention.
    Dec 20, 2017 | Ovens
    Tricity Bendix SE556SV lower oven not reaching tempature, new element, themostat and fan
    First need to see if supply voltage is correct.
    Verify oven probe sensor to the thermostat Is working properly? (usually done by Ohm test)
    Thermostast offer an option for calibration?
    Also have you verified actual oven temperature with an external thermometer?
    Jun 09, 2015 | Ovens
    Main Oven does not reach required temperature
    check gas pressure and burner if ok bad temp sensor
    May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
    Bottom Oven Fan on Whirlpool AKP951 not working properly
    Sounds like the fan is locking up and not turning all the time. If it is a howling sound the fan will have to be replaced.
    Nov 29, 2011 | Whirlpool Ovens
    My Neff eletric oven works on top and bottom heat, but does not heat up on the fan setting fan. It heats slightly and the fans works but it does not reach temperature.
    You need to replace the oven element
    This is located at the rear of the oven compartment behind a removeable cover, it is usually circular in shape
    Jan 26, 2011 | Neff B1421 Electric Single Oven
    Looking for a manual for Whirlpool BS0801/WH oven
    I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
    The function symbols on Knob F, clockwise from the top, are as follows:
    • 0 = Off
    • Lamp symbol = Lamp Only, no fan, no heating.
    • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
    • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
    • Final position = Grill. The temperature of the Grill is set on the Grill knob.
    The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
    The bulb is 25W 230V Type E-14 300 Degree C.
    The oven draws a maximum of 2300W so requires a 10A supply.
    Nov 29, 2010 | Ovens
    Main cooling fan switches on and off rapidly
    hi there,
    could i get the exact model # for your stove please?
    Sep 14, 2008 | Tecnik Ovens
    Hotpoint double oven
    Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
    Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
    My oven turns off on me after only a minute never heating up fully
    Could be caused by either of following;
    1. Faulty thermostat.
    2. Faulty thermal cut out switch. (controls power to cooling fan).
    3. Faulty cooling fan (not fan inside oven).
    Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
    To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
    When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
    If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
    Jun 19, 2008 | AEG B1180-4 Electric Single Oven
    Ovens Logo
    24 people viewed this question
    Top Ovens Experts
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you an Oven Expert? Answer questions, earn points and help others
