Question about Seloc Mercury Outboard Engine Repair Manuals SEC-1416 1990-00 2.5-275 HP
25 hp merc. have replaced push button switch and solenoid.have power to solenoid and start it by jumping the solenoid. starts fine pulling rope.no response at switch.
  • Seloc Master
  • 3,497 Answers
With the info provide, sounds like you still have a bad solenoid..
1. Take your battery to a battery shop and have the cold cranking amps checked.
Posted on Jun 13, 2017
My push button start switch not working on M/C..
Sounds like a bad relay... the relay switches all power to the solenoid to start the bike... when you let off of the starter it turns the lights etc back on. If the relay goes bad... starter button will not work, and no power to the headlight/taillight/dashlights... the relay is fairly cheep, 10 to 15 bucks....so its a pretty cheap test to see if that is what is wrong.
Mar 22, 2014 | 2005 kawasaki EN 500 Vulcan
Mower won't start with ignition key
did you replace stater relay switch
Jul 09, 2013 | Garden
1200 suzuki bandit, won't button start, will push & jump start, checked fuses
Try pulling the switch open, and clean the contacts, or make sure everything still connects as it should.
Check your connections at the starter and solenoid.
Mar 14, 2012 | Motorcycles
Intruder not starting.
You are in neutral, clutch pulled in, kick stand up when you push the button?
Check the voltage on the starter side of the solenoid when you press the start button. Your solenoid may need service or replacement. You may also be able to jump over the solenoid with a heavy cable brom the battery to see if the starter will run.
Try either, MAKE @#$%@ SURE you are in N and the clutch is pulled in before you try this stunt.
Thanks for using FizYa.com
Nov 01, 2009 | 2001 Suzuki VL 1500 Intruder LC
1997 VW Cabrio When ignition is turned to start nothing happens. Selinoid and starter are fine. No elec to triger wire to selinoid. I pulled conector from back of switch and jumped from hot to start and...
if you have power to the solenoid on the starter pull in post but nothing happens thenthe brushes need to be replaced in the starter.the brushes let the solenoid go to grounrnd for the lenght of of time it takes to engage the solenoid pull coil and the switch and relay take over during the hold mode of the starter.usually will find the lead from the solenoid to the brushes has rotted off,or brushes are gone.
Aug 20, 2009 | Volkswagen Cabrio Cars & Trucks
14 hp dynamark tractor that won't start
Have you checked the inline fuse?. Also you could unplug the ignition switch and clean the terminals, particuarly the one with red wire in it. That the one that has constant power to it and tends to corrode over time. Hope that helps.
May 23, 2009 | Garden
Seloc Mercury Outboard Engine Repair Manuals SEC-1416 1990-00 2.5-275 HP Logo
97 people viewed this question
Top Seloc Boating Experts
Bill Boyd
Steve P
Steve P
Are you a Seloc Boating Expert? Answer questions, earn points and help others
