Question about Samsung Televison & Video
If the picture and sound both went out while watching a Samsung UN65HU9000FXZA TV, is it the T-con board that needs to be replaced?
zjut
  • 106 Answers
SOURCE: picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Posted on Jan 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: SAMSUNG HLR4667W LOST PICTURE AND
sounds like the DM module not powering up.
Posted on Feb 27, 2008
  • 718 Answers
SOURCE: sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Posted on Mar 10, 2009
  • 20 Answers
SOURCE: no sound no picture went blank .
Do not panic! Do not throw your TV away like I wanted to! Here is what may be the solution for most of the members who have posted their complaints here recently. I am not an expert, but I followed all blogs from various websites and forums, and the conclusion was the same;replace the convergence board for this model. I purchased it from www.partstore.com and since this Akai is the same model asa comparable Samsung Model, buy the Samsung comparable Convergence board for $77. It came to about $85 after shipping. Call them if you need the exact model #. The Convergence board has two black STK ICs and two colors of wires, a gray kind and a blue kind,all which have 'pins' and can easily be unplugged from the circuit board in the TV. It is basically a complete system that takes less than 30 minutes to install. It is a simple swap procedure, with no soldering.You only need the new board and a screwdriver! Remove the lower backboard of your TV where the cables are plugged in (do not unscrew all the screws for the screen, as it is unnecessary, and might just damage your screen if you are not careful.) It has a u-like shape and comes off easy.Detach the gray wires connecting your old board to the rest of the circuitry, and detach the blue wires connecting the old board to the circuitry. On the old board, there are connectors marked,from left,blue, green and red. Detach those from the old board, and mark the wires so that you may connect the correct the wires to the new board. You then unscrew the only screw connecting the board to the TV,and unhook the board from the TV. Hook the new board to the hooks which held the old board, and screw the lone screw to the board. Plug the gray cables from the new board to the connectors where the gray cables from the old board were,and do so for the blue cables. Connect the multicolored cables to the blue, green and red, just as was done on the old board. Reattach the cover and test the TV. Please do not replace the two STK ICs only. When I removed my old board, I realized that there was a burn mark, where the ICs were, but maybe it was a fuse.You may replace the ICs only to discover that it was another problem.Good luck, and I wish you all the best in the repairs. I just saved about$100 for a repairman just to show up.
Posted on Jun 16, 2009
  • 267 Answers
SOURCE: 42 inch DO42746 no picture or sound
It is still possible the z sustain board is bad. or an x driver board.
Posted on Jun 26, 2009
I have a Samsung tv. The picture went out but still had volume and backlight. I watched your video and changed the t con board. It worked! However, now the picture is upside down. Ideas?UN50EH500F
I would guess that either you got a connection to the T Con board wrong or maybe you got the wrong T Con board altogether! You have to check the numbers of your T Con match the old one and that it looks the same. If they do then it will be fitted in wrong assuming that there wasn't an issue with the set before.
Jan 04, 2017 | Samsung Televison & Video
I have a Samsung UN55ES6100FXZA LED TV. Picture went out, but there is still sound. I replaced the PCB Power Supply Board BN44-00503A and I have the same problem. Any suggestions? Thank you!
I had a Samsung TV with sound but no picture, All the controls also worked. The problem was the T-Con board. Make certain you get the right one, or it will not work.
Dec 01, 2016 | Samsung UN55ES6100FXZA
Samsung TV
If you see a picture with the flashlight you can rule out the T-Con board. It's working. So the led driver board is the problem. TV Parts Universal TV Stands DLP Chips ShopJimmy Go here for replacement parts.
Aug 07, 2016 | Samsung Televison & Video
My samsung ln46c630k1fxza 46 inch t v that has no picture or backlights, i replaced the t-con board, that didnt fix the problem. can you tell me how to fix the problem?
Samsung LED TV Model UN46D6400UFxza has sound but ...
? 2:16
https://www.youtube.com/watch?v=s2hLKzdyDWU
Oct 21, 2013 - Uploaded by Clif Venom
Samsung LED TV Model UN46D6400UFxza has sound but no picture ... LCD & LED TV Repair - No Image ...Missing: ln46c630k1fxza
Samsung LCD TV screen went black (audio on, no picture)
Dec 20, 2015 | Samsung Televison & Video
Samsung LCD TV, no picture, but sound and backlights work. Not t-con board. Any ideas what it could be?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 05, 2015 | Samsung Televison & Video
How to fix LED TV
probably the T con board is faulty. T con broad is the one which drive the LCD pixels. Watch the video to identify the T con board.
Samsung LED TV Repair Con Board Replacement No Picture on Screen Image...
www.electro-medical.blogspot.com
Sep 18, 2015 | Samsung Televison & Video
Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
Samsung lcd
See if it is on all inputs and modes. If so, unfortunately it is because it is a failure of the T-con board on the LCD Panel. If you are lucky, the T-Con board might be available but usually the only way to fix it is to replace the whole LCD panel. This is because the T-cons are rarely available by themselves. The LCD panels usually cost $500-$3000 depending on the model while the t-con is about only 1/10 of the price.
Oct 06, 2009 | Televison & Video
Televison & Video Logo
26 people viewed this question
Henry  Thomas
Henry Thomas
