How do I operate this machine - Washing Machines
  • 10,060 Answers
What machine????
Posted on May 17, 2017
Please how do I work a zig zag pattern on my manual operated singer sewing machine
Hello, Annelien -
Unless your manually operated sewing machine has switches to realign your sewing machine needle to make zig zag stitching, as is demonstrated in this YouTube video (starting at around 6:30 minutes in the video):
you cannot. Note: The machine in the video is a Necchi brand sewing machine.
Without knowing the model number of your manually operated Singer sewing machine, I cannot try to find operating instructions for it to determine if your machine has zig zag stitching potential.
Best wishes.
Jan 24, 2018 | Singer Sewing Machines
Why does my needle keep breaking and bobbin case makes clicking sound and locks up on me?
If this is a new machine to you please get and read the operator's manual before trying to operate. Super fast, and powerful machine be careful as you learn how to properly operate it.
San Diego, CA
Embroidery Services
Mar 12, 2015 | Juki DNU-1541 Industrial Walking Foot...
Emachine EL1852 keep on restarting
Does it load operating system fully before restarting?If it does,run a full scan of the drive with an updated anti-virus.
If not,do a reboot[enslave] of your hard disk from another computer.This is how to:-
Remove the hard disk from your machine.
Disconnect CD/DVD ROM from machine 2 and connect your hard drive.
Start the machine.'You're trying to run Unix' alert comes on, press f1[ save changes].
A disk check operation starts.This repairs the operating system on your hard disk.
After successful loading operating system of machine2,turn it off and remove your drive.
Fix it on your machine and start it.
Hope this helps.Thanks!
Sep 27, 2011 | E-Machines eMachines Desktop PC
I am getting error 244 when receiving a fax.
errors 243 and 244. Taken from HP.
The user of the remote machine has pressed that machine's Stop key causing the session to be prematurely terminated. Alternatively: the remote fax machine determined there was a feature incompatibility between the two machines and has terminated the session. An example would be when the local machine wanted to initiate polling, but the remote machine did not support this mode of operation.
1. Confirm the remote user is not inadvertently attempting to poll transmit from the local machine, instead of transmitting to the local machine. This mode of operation must be specially configured on the local machine. If poll transmission from the local machine is the desired mode of operation, confirm the local machine has been configured for this operation.
2. Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed
Sep 20, 2010 | HP 910 Plain Paper Inkjet Fax
Engine occasionally jams, still able to operate manually
It's been a while since this machines been oiled. try oiling both motor hole and needle operation.
Jan 24, 2009 | Singer Inspiration 4206
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Anti virus software for slow speed machine turn on security privacy risk in advanced settings
Nov 05, 2007 | Microsoft Windows 98 for PC
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
