Question about Frigidaire Dehumidifiers
EC code on Frigidaire 50 pint dehumidifier will not clear when unplugged and plugged back in also none of the buttons will operate. do I need to buy a new sensor and switch board?
22yooper
  • 828 Answers
SOURCE: 2008 Frigidaire 50 pint Dehumidifier from Lowes
You can test it out by disconnecting the power cord, wait five minutes and plug it back in. If it retains the original settings you are good to go. If you are wondering before purchasing a new unit ask before you buy.
Posted on Jun 29, 2008
Dittoz
  • 3 Answers
SOURCE: my kenmore 50 pint dehumidifier 54501 runs but it
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The 'coil' (a finned metal part that needs air to flow across its surface) may be filled with dust and obstructions, so no air can move...then no water. There is a blower motor that must move the air. If it is seized up and not blowing air...very little or no water. The compressor creates condensation from air moving across the coil (like the moisture than forms on an ice filled glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Posted on Jul 31, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 05, 2010
SOURCE: I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
Posted on Jun 17, 2010
heatman101
  • 43501 Answers
SOURCE: Frigidaire 50 pint dehumidifier freezing up and
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on Jul 13, 2010
Why does compressor continue running, even with dehumidifier turned off?
Hello Bernard, thank you for your post!
I see that you are experiencing an issue with the Frigidaire dehumidifier, FAD704DWD, compressor consistently being on. This could be a possible issue with your control panel or sensor. Since it could be any one of these underlying issues I would suggest contacting the manufacturer for further assistance. Hopefully this information is helpful to you. -Matt
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
Dehumidifier seems to be running fine, but water leaking on floor even with minimal water accumulated in bucket?
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
Sep 13, 2014 | Frigidaire FDF50S Dehumidifier
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
Kul dehumidifier error code as unplug and plug back in still has the error code.
"For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service."
https://edgestar.zendesk.com/hc/en-us/articles/201000315-My-dehumidifier-is-displaying-an-error-code-What-does-it-mean-
Apr 28, 2013 | KUL 65 Pint Dehumidifier
I have a Haier 65 pint dehumidifier. When I press the control button to lower the humidity setting, the word On comes up and I do not see numbers lowering.
Let's start from the beginning. Turn the Master ON/OFF Switch to OFF. Unplug the unit for 5 minutes. Then plug the unit back end, and turn the Master ON/OFF Switch to ON. Now, lower the the humidity extraction level to 40%, by using the Arrow Down Button. You will need to lower it by pushing the button for each % setting. DO NOT push and hold the Arrow Down Button.
Doing the above should solve the problem.
Jul 12, 2011 | Haier HDN655E 65 Pint Dehumidifier...
I have a 50 pint Fridigidaire dehumidifier and can't set on a continuous mode. can you help?
The unit may simply need to be reset. To do this, turn the Master ON/OF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging it back in. Turn the Master ON/OFF Switch to ON and the set the controls as you would like.
I will remind you, that operating in continuous mode, the dehumidifier will consume a lot of electricity and have little or no chance to cool off. Other than when the tank is full and needs to be emptied.
Hope this helped you to solve the problem.
Apr 12, 2011 | Frigidaire Dehumidifiers
heatman101
May 04, 2010 | Frigidaire FDL60P1 Dehumidifier
Apr 25, 2008 | Frigidaire FDL45P1 Dehumidifier
Dehumidifiers Logo
149 people viewed this question
Top Frigidaire Dehumidifiers Experts
Lawrence Oravetz
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
