Question about Maytag Washing Machines
How do i reset the control panel for maytag model #mfi2269veq5.
2 Suggested Answers
SOURCE: Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
Maytag fridge buttons won't work properly with NEW control panel. Reset isn't working.
Hello DaVe;
My name is peter. I am a retired field service refrigeration technician.
What are you doing. You replace a control board and wasted your money.
Send me model number, which is located on the inside liner panel of your fresh food section on a label.
Please do not spend any more money guessing.
Apr 01, 2015 | Maytag Refrigerators
My maytag dishwasher model MDB7749SAM stopped working about three days ago. The start/resume button flashes continuously and won't turn off. I flipped the breaker switch but nothing reset. The cancel...
Most likely moisture has affected the switches in the panel or the controller is faulty.
Refer assembly shown in the link below. Open the panel and locate the ribbon cable. Carefully take it out and with a hair dryer lightly dry up the parts. Put everything back and turn power back on. If no difference still then you may have to replace the control board.
MAYTAG Undercounter Dishwasher Control panel and latch Parts Model...
Aug 01, 2014 | Dishwashers
Maytag Refrigerator Model Model #MFI2568AES
This a common problem with these units the high voltage in the main control board is the problem, the main control board in the back will need to be replaced. This runs about 250 dollars for the part. You can order it from this link.
http://www.repairclinic.com/Maytag-Refrigerator-Model-MFI2568AES-ID-657261-Parts?n=2
Nov 09, 2013 | Refrigerators
My dog locked the control panel on my epic maytag washer
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
Service Manual
Apr 04, 2011 | Maytag Washing Machines
Have replaced the water filter - how do i reset/turn off the "change filter" light ?
Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • May 18, 2010 | Maytag MZD2766GES Side by Side...
    How do I unlock the control buton on my maytag front load washer model MFW9700SQ0.
    The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
    With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
    If this is a Whirlpool manufactured front loader, the following link explains how to lock/unlock this feature:
    http://www.fixya.com/support/r3608801-control_panel_lock
    These instructions are printed on the front panel of the appliance and in the owner's manual.
    If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue).
    If you have any questions, please let me know. I hope this helps you.
    NOTE: This model Maytag is manufactured by Whirlpool, so these instructions do apply.
    Apr 16, 2010 | Maytag Neptune MAH5500B Front Load Washer
    My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
    OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
    CONTROL PANEL(CLICK HERE TO ORDER)
    Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
    Blinking lights, unresponsive
    I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
    May 08, 2009 | Dishwashers
    Maytag Dishwasher
    Jul 01, 2008 | Maytag 24 in. MDB5600A Jetclean II...
    Washing Machines Logo
    46 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
