Question about Garden
The deck on my lt1045 is leaning to one side and cutting on an angle this just happened any adjustments I cant seem to find the manual
  • 208 Answers
SOURCE: have a double picture. manual
If the convergence will not adjust then 1 or more of the convergence amp ic's have failed. Most times just replacing the ic's will correct the problem, but sometimes when and ic fails there is other damage such as open or burned resistors or open cp (circuit protect fuse). If you want to reply with a make and model I can provide part #'s and locations.
Posted on Apr 16, 2008
  • 227 Answers
SOURCE: uneven cut
I suggest you park the tractor on a level hard surface. Measure from the bottom of the deck to the ground on both sides of the deck to see if it is mounted level. The next thing to check for is a bent blade. Good luck.
Posted on Jul 06, 2009
harlan301
  • 205 Answers
SOURCE: Seems to start easily run for a few minutes and
your filter may be hanging up in the tank. you also my be losing compression
Posted on Oct 13, 2009
nova2nv
  • 197 Answers
SOURCE: adjusting John deere ''Sabre'' model deck
Move machine to flat/level surface,with deck raised put a 2x4 between rear of deck and ground.Make sure that the 2x4 goes all the way under deck from one side too the other.Once that is done lower deck all the way and make sure lift lever is all the way forward.Then on the rear top side of deck loosen bolt that holds arm to deck bracket,pull bracket as far down as you can then retighten bolt.This is also the point where you can level deck side to side.
Posted on May 05, 2010
  • 8404 Answers
SOURCE: the mowing deck on craftmans lt200 is leaning to
I think one of the hangers has become disconnected. There should be a leveling procedure for this in your owners manual. If you dont have that manual ... you may find the leveling procedure at the Sears web site. Leveling procedure is pretty standard ... the basic idea is get on a level surface --- your garage --- measure from the deck to the floor on 4 corners ... make adjustments as required front to back and then side to side. Once you are on the floor ... you will see what to do.
Posted on May 15, 2010
How to level the mower deck
There are many possible answers, but the best way I've found and for all types of mowers is:
Put the mower on a level garage floor or pavement area. Rise the mower deck to the highest level. By hand (everything off, of course), position both blade tips to the furthest outside edge of the mower deck (widest from tip to tip). Use two wood blocks or equivalent sized objects and place them under the blade tips. Find something that comes very close to the blade but doesn't touch. This is so you can see a gap for reference sake. Adjust the linkages (usually long links, from front of tractor) until the spacing is the same between both blade tips and the objects under them.
The manual has you measuring the blade tips. I find blocks or spacers easier...
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf - see page 17
May 25, 2016 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
My lawm mower dont cut evenly
need to adjust deck side to side height and front to back height. this is usually in the owners manual. just search for your model number and you should be able to find it. if you cant, let me know and i will see if i can.
Jun 24, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman LT1000 model # 917-275351.It cuts crooked and I don't have an owners manual.How do I adjust it to cut evenly
2 ways to adjust deck level, the obvious is the ground wheels. The other is adjustment rods that hold the deck to the under side of the frame, usually 2 rods one on each side and maybe 1 in the front of deck/frame
Jun 13, 2014 | Craftsman Garden
My 42 inch Toro seems to be cutting unevenly. The blades seem to be on correctly and I hope I haven't hit something to set the angle wrong
First thing to check is that the deck is level by the adjustments on wheels. Then check the bearings in the spindle housings and there is no play in the shaft when you try to move blade up and down. You then can measure from the blade tip bottom of deck on both sides (3 o'clock and 9 o'clock, and then 12 o'clock and 6'o clock They should all be the same. If not then either the shaft is bent, or the deck is bent slightly causing the blade not being parallel to the deck. If you have someone rotate the shaft you should be able to tell if the shaft is bent or not. If the deck is bent, then you will have to straighten it out till the spindle shaft is perpendicular to deck.
Oct 14, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
I have a Craftsman Lawn Tractor model 917.28712. 20 HP and 42 inch cut. The mower cuts uneven, lower on left side. My Op manual says that I have adjustments on both side. I only have an adjustment on the...
If tires are the correct inflation, check the angle of the deck. The blades may need to be sharpened. There is a blade balancer you can purchase. If one blade is not as sharp as the other, it will have a little more weight on one side than the other.
Aug 16, 2010 | Garden
Hi, got a Craftsman 20 Hp 42 inch cut , the Deck will not lay flat, it is always on a angle. any ideas ? No matter what the cut height is set at.
Hi tubbed,
Most of these decks are held on at three points. Two are in line 90 degrees from front to back. The other is attached to the height adjust lever.
The first two are adjustable to change the type of angle problems you are having. Make sure you have the engine off when checking. Adjust until the desired angle is reached.
Also, if the model your problem is categorized under does not match your model, the cause of the angle and the solution may be different.
Best regards
Mike
Jul 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The mowing deck on craftmans lt200 is leaning to one side. this causes an uneven cut
May 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hower do you do the adjusting for height on the
The dial only sets the height or the total deck, it is more of a stop than an adjuster.
If it seems too low in the front, you can adjust it by tightening the nuts on the 2 bolts/pins that are attached to the deck and the frame.
First of all, though, check your tire pressures, 10 psi in the rear and 14 psi in the front. If front pressures are too low, this will make a huge difference in your cut. You want to adjust the bolts an equal amount to maintain your side to side level keeping in mind that it should have 1/4 to 1/2 " difference front to rear.
Make your adjustments on your driveway or garage floor so you have a flat level surface to go by.
If you make these adjustments and it still scalps, you will either have to set the deck to cut a bit higher or approach the high spots from a different angle or remember to lift the deck up a bit with the handle when you get to those areas
Hope this solves your problem
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
