Question about Hardware & Accessories
I have a Melnor aqua timer 3015. The timer starts properly but does not turn off. What wrong?
3 Suggested Answers
manhandy
  • 146 Answers
SOURCE: Can't correct the current time in the Melnor 6
go to there web Site
Posted on Jul 13, 2009
mikeruth12
  • 3 Answers
SOURCE: I have a Melnor 3015 aqua timer (2007 model) that leaks. I am fairly certain it is the connection between the solenoid and the valve but I cannot figure out how to open the thing without breaking the
I have a fix for this Melnor Model No 3015. You can you a razor knife and keep scoring around the whole thing along the seam line, and it will take you at least 35 minutes to get into it, but it will come apart. Mine (with new batteries) the display worked fine. All the buttons worked except the valve would not come on when I clicked manual on or off and if I programmed it to come on it would not open up the water valve. After getting apart (and note I had it all connected with the water pressure on and I had no leaks.) I think if your unit is leaking you will definitely need to open up your unit to see what actually is leaking. It could be that water was in it durin the winter months and froze it (thereby cracking the housing) as with my unit I manually was able to move the white small gear to manually open and close the valve. I then placed the metal connectors on the 9 volt battery and got it to switch at least a few times so I am thinking it just may nred to be lubed up??? Any suggestions??
Posted on Jul 07, 2016
Melnor Aquatimer leak
The seal inside the timer is defective.
Jul 06, 2017 | Refrigerators
The brand new timer just installed is leaking profusly from the connector to the faucet...?
turn water off at the main then put Teflon tape on threads then re attach..................problem should be solved
Apr 18, 2016 | Melnor 3280 Digital Aqua Timer Watering...
How to fix a melnor 4 zone digital timer with stuck valves?
bleed the air out of each valve then re tighten bleed screw. if still stuck open then buy new diaphrams
Dec 13, 2015 | Melnor 3280 Digital Aqua Timer Watering...
It's made that way. The case is not meant to be opened, it's a sonic weld (melts the plastic together). It's meant to be a disposable device; it breaks throw it away and buy a new one. Also known as planned obsolesce.
Jan 24, 2015 | Melnor 3015 6 Zone AquaTimer
Melnor 4 zone aqua timer dosent follow program
Water timers and Melnor timers last a year or two. They come with 1 year warranty for defects in workmanship.
Change batteries, reset timer if there is a reset protocol, buy another timer. Melnor, Orbit, are major brands. Gardena is not supported. Yardworks repackages other brands.
Copy following link for all watering and irrigation timers on market, with links to manuals for each brand:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add a comment and say what you find.
Jun 20, 2013 | Aqua Hardware & Accessories
Timer 3018AR manual
Timer could be Melnor 3015 or Melnor 3018
Copy following links to download possible manuals:
http://waterheatertimer.org/pdf/melnor-aqua-timer-3015-B.pdf
http://waterheatertimer.org/pdf/melnor-aqua-timer-3015.pdf
http://waterheatertimer.org/pdf/Melnor-3018.pdf
Jun 05, 2012 | Hardware & Accessories
Hardware & Accessories Logo
32 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
