Question about Hitachi (14R9464-20PK) 250 GB Hard Drive
File system currupted/hard disk problem
Hi
i have a problem with my hard disk[Hitachi 250 GB Hard Drive]
when i was installing OS-windows xp during the process there was a
power interruption so the system turned off.
Agian after i tryed to install os but it showing only 3-drives and some unpartioned space(i.e. equal to the lost drive.Actually i have 4-drives
after loading os i lost the remaining two drives also
is there any way to recover my data
is there any way to recover data from a formatted disk
please send me a solution
thank you
  • Anonymous Apr 01, 2009
    my hard drive space vanished....wtf
  • 1,006 Answers
Yess it is just email me at : fixya-expert@live.com and i will send you instructions how to recover data...
Beni
Posted on Nov 21, 2007
    Scholar:
    New Friend:
  • 77 Answers
Stellar Phoenix Windows Data Recovery platform for Windows users to easily recover lost, deleted, or inaccessible text files, image files, media files, emails, and other piece of valuable information from any Windows-based storage device and RAID servers. The software also recovers data from damaged optical media and supports wide range of CD / DVD / BD / HD DVD formats.
Posted on Oct 13, 2016
Ur hard disk may be infected by CIH virus.
If u want to recover ur data then try DATA RECOVER PROFESSIONAL 6.0.
good luck
Posted on Feb 28, 2009
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
I have LatitudeD510 and my disk makes lot of noise. Its on Windows7 and I think the disk is a Hitachi - HTS541040G9AT00
HI,
chances are that you simply do not have the resources to run windows 7. These are the basic (recommended minimum), for windows 7
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor.
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit).
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit).
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • 1 more GB of RAM & 15 GB more HDD space to run 7 in XP Mode.
These are the typical resources that come with your machine.
D510HI
  • Processor Pentium M 1.73 GHz
  • Ram Installed Size 512.0 MB
  • Technology DDR2 SDRAM
  • Hard Drive 40.0 GB
  • OS Provided Microsoft Windows XP Professional
It would probably be advisable to go back to XP
Good luck
Jan 07, 2011 | Hitachi Travelstar 5K100 HTS541040G9AT00...
How cAN I INSTALL WINDOW 98 OVER WINDOWS XP IN THE NTFS FILE SYSTEM
For that first you need to delete that ntfs patition becasue win98 disk not supports ntfs.
For deete partiotion you can use dm tool or winxp bootable disk then delete NTFs partition then boot computer with win98 disk thats it.
Aug 19, 2009 | Seagate (ST3250824AS) 250 GB Hard Drive
My system is not stable
Can be virus...hardware..or o/s issue
  1. Try taking unwanted files or prrgrams
  2. empty the temp folder
  3. Scan using latest anti virus
  4. Defragment
  5. if still same. Try formatting and re-installing the o/s..
  6. if still the same check replacing HDD ...or M/B
May 22, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Hard disk drive not detected
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
May 27, 2008 | Hitachi hts548080m9at00 80 GB Hard Drive
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Hitachi (14R9464-20PK) 250 GB Hard Drive Logo
345 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
