Question about Kodak Office Equipment & Supplies
My Kodak Printer ESP 5250 continually gives me a paper jam error code 3533. There is no paper jam. How can I fix it?
SOURCE: canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Posted on Jun 16, 2008
  • 285 Answers
SOURCE: error code 3820
try the baack of the printer. open it up from the back
Posted on Jan 28, 2009
SOURCE: Paper jam in a Kodak ESP- Printer
i had the printer jam issue when there wasnt a real printer jam.
if you push the print cartidges off to the right, then reach in and push down on the cleaning head that is located on the left on the inside, it pops back down into place and voila, printer jam error message fixed.
Posted on Jul 04, 2009
  • 295 Answers
SOURCE: Kodak All-in-one Printer has Paper Jam problem
Go to and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Posted on Oct 20, 2009
  • 64 Answers
SOURCE: got a paper jam how do I take off the back to fix
Log onto and follow the online steps to either resolve the issue or tell you to contact Kodak for replacement.
Posted on May 13, 2010
Testimonial: "Was helpfull"
Printer give a paper jam error when there is no paper in the machine
Hi, thank you all for your replies & sugestions. I think I've tried everything now apart from talking to Kodac and cleaning the paper sensor. Where do I look for the sensor ?. I've had the top cover off & can't see anything.
Many thanks.
Mar 27, 2016 | Kodak ESP 5250 All-in-One Printer
How do you open the rear door to fix a paper jam on a Kodak 5250 printer?
There are two plastic tips that you pinch inward at the lower back of the printer. A rectangular plastic piece will come out if you give it a god tug and you should be able to remove any jammed paper. I took mine off and never put it back on because it is aggravating to remove. I also had a problem of every 5-6 sheets of paper would not feed correctly through the printer and a paper jam notice would be displayed. I have all but remedied this too by stretching two heavy duty rubber band around the paper dispensing tray close to the bottom to provide more tension on the paper feeder itself. WORKS GREAT FOR ME! GOOD LUCK! Mine is a Kodak esp 3.2 but it paper jams a lot so maybe this will help you some as well?
Aug 09, 2014 | Kodak ESP Office Equipment & Supplies
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Sep 12, 2013 | Kodak ESP C310 AllInOne InkJet Printer
Paper jam code 3533
In removing the jam you have pulled aswitch in side loose . Usually a plastic black switch that will trigger this . It is inside and will need to be reset inplace.
Aug 27, 2013 | Kodak ESP 3 Multifunction Printer/ Copier/...
Koday esp c310 error 3533
I have code 3533 code but paper is not jam
Sep 13, 2012 | Kodak ESP 5 Printer
Get a paper jam error code 3533 but nothing in the copier.
I hit on mine several times and slammed it on the table a few more times and it cleared the jam. Seriously.
Apr 04, 2012 | Kodak ESP C310 AllInOne InkJet Printer
Esp 5250 error code 3528
Hello Shaheen,
Try this:
To resolve the error:
  1. Press the On/Off button on the printer control panel to turn off your printer.
  2. Wait 30 seconds.
  3. Press the On/Off button to turn on your printer.
If the error continues, double-check that all paper and foreign objects are removed from inside your printer.
NOTE: Even if you do not physically see a paper jam, you will need to follow the paper jam link to solve the error.
Paper Jam Error
Oct 19, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My kodak esp5210 printer is showing paper jam remove rear access cover. clear all papper. attach cover. press ok to continue. (code 3533). ive followed the instructions but nothing changes. there never...
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. (
Feb 11, 2011 | Office Equipment & Supplies
Kodak esp 5210 code error 3533 paper jam no paper in it
Leave the rear cover off, then spam the OK button if the error message remains on. I did that maybe 10 times in rapid succession, then hear a very distinctive CLICK in the back of the printer. I replaced the cover, the hit OK, the printer cycled through startup, and now it's operating normally.
Jan 17, 2011 | Kodak ESP 5 Printer
22 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
