Model 41182311 will not clean clothes. - Washing Machines
Dryer eating clothes
It may be running way too hot. If the filter is clean there may be a thermostat issue.
Mar 19, 2014 | Dryers
Washer doesn't get clothes clean
What is the model number of the unit?
Nov 30, 2012 | Washing Machines
What do I use to clean the screen on a sane flat screen. Model # dp32649
The best is a mild solution of washing up liquid and clean warm water.
Use a clean lint free cloth and wet the cloth, wring it almost dry and wipe the screen over until clean.
Repeat this as often as required making certain not to let the cloth drip down the front of the screen.
Hope this helps
Dec 13, 2010 | Sanyo DP32649 31.5 in. TV
Whirlpool duet dryer model # GEW9200LW1, when powering up goes directly to touch up, and will not start. thermal fuse ok
Dirty moisture sensing strips? Have you tried cleaning them with windex?e03f8f0.jpg
Number 34 these measure resistance by picking up wetness from the clothes. Dryer sheets can coat these with a non penatrable film which fools the brain into thinking them clothes is dry so it moves towards the cooldown mode and shuts off with wet clothes. Clean them sensor strips real good and party on!
Oct 11, 2010 | Whirlpool Dryers
Hitatchi lcd tv model 32LD6600 B can I clean
Yes,take a cotton cloth damp it with some water nothing else,softly move all around the LCD screen to clean the dust off.Or tries Ebay.com,Amazon.com to buy a package of cloth call the Micro Fiber clothes to clean.These Micro Fiber clothes are for cleaning eye glasses,deligate surfaces,and electronic devices screen.
May 18, 2010 | Televison & Video
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Have duet electric dryer model #9200Lw1 dries slowly
are you overloading the dryer, too many clothes would take longer to dry
Feb 03, 2018 | Whirlpool Dryers
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
Some clothes not clean or even completely wet after wash cycle finished
Ebay item number 200262803398 is a cheap PDF service manual for this model.
prem
Oct 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Cleaning
Its a hard reach, but remove the back, unplug the set then remove the two screws that hold the small shelf around the tubes then reach up on the rear panel and clean and dry the mirror,Dont use windex ,just a damp cloth then dry it. then clean the lenses of the 3 CRTs and then also clean the screen with a damp cloth and dry. Remember dont use windex, just a damp soft cloth so as not to scratch anything
Mar 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
