Question about Dishwashers
Polycrylic after 24 hours still cloudy. applied to a concrete statue that sits inside my entryway. wwill it ever go clear
Water based paint removal on concrete
wet the surface, apply commercial grade citric acid.......let it sit for a bit....come back and pressure wash the surface, repeat as needed.
Sep 01, 2014 | Building Materials
How do I fix a wobbly in ground basketball hoop
I would clear any loose debris, repack around pole with a dry concrete mix then add water to it make sure pole is level, brace if necessary and give 24 hours to set up.
Apr 18, 2014 | Basketball
I want to strip the concrete floor that I use jasco seal 6 years a go do you have any product I can use .
  • 1 Make sure that the surface of the concrete is cleaned thoroughly. Remove stubborn dirt or stains with a mixture of one part degreasing cleanser and two parts water. Rinse the concrete well and wait 48 hours before continuing.
  • 2 Use a large paintbrush or a long-handled paint roller fitted with a fine-nap roll to coat the entire concrete surface in a thick layer of soy-based or other environmentally-safe chemical stripper. Allow the stripper to eat away at the sealant for 10 minutes, scrape up the peeling sealant with a paint scraper or putty knife. Clean up all of the debris.
  • 3 Rinse concrete to remove all of the stripper. Let the concrete dry 48 hours. Apply the new sealant or the finish of your choice .
  • Oct 21, 2013 | Jasco Wet Look Cure Seal 0613-GL Set of 4
    Top 2" of my concrete wall has eroded. How do I fix it, so it will last, and make sure new concrete bonds to the old?
    There are different kinds of concrete coating. The choice of product varies, depending if the wall is interior or exterior and on the location of the wall (for example the product used in a bedroom's wall will be different from the coating adopted in a garage).
    Epoxy coating are great products that can be used in exterior or interior. Epoxy products however may smell and trigger allergies. Epoxy is one of the strongest coating for exteriors.
    If the space is a living room, then it is probably better to use acrylic cement. Acrylic coatings do not smell and do not release volatile compounds. Acrylics look similar to Portland cement and are generally less strong and adherent than epoxy paste.
    The application method is usually illustrated in the coating product's container. The procedure consists in cleaning the wall (you can use a power washer), applying the product with a trovel, and then checking the results after 24 hours or when prescribed in the coating's instructions.
    After applying the coating you can finish the wall with paint and sealer product.
    Oct 18, 2013 | Yamaha RX-V757 Receiver
    How long does concrete take to dry?
    it will be dry enough to touch after 24 hours. chemically speaking, it continually dries and becomes harder forever
    Jan 15, 2013 | Building Materials
    I have porch lights that are controlled by a switch in front entryway and also from garage. (3-way) I want to put a timer in entryway and by-pass the garage so lights come on from only one location.
    Identify which of 2 switches has the Hot or Power wire.
    Hot wire will be connected to dark screw on one of the switches.
    If Hot wire is in garage box, then follow this Step 1-2-3 diagram for ST01C timer:
    If Hot or power wire is in entryway box, then you have a '3-way no neutral,' so cap off 3 wires going to other switch. ..
    And then wire ST01C timer as single pole no neutral.
    Oct 23, 2012 | Intermatic Inc. ST01C Digital In-Wall...
    My water looks a little cloudy. how do i clear it up. and are you supposed to shock your pool once in a while.
    My wife takes care of our pool chemicals. When it gets cloudy, just hit it with a normal dose of chlorine. A normal dose is what you would put in in a given day. Run the filter for 24 continuous hours if necessary.
    Aug 09, 2011 | Intex Krystal Clear Model 635 Pool Filter...
    After 24 hours water damage does sitting a nintendo ds in rice after 24 hours work.
    Most likely not, because the water damage has already damaged the circuits and the other components of the DS, and if there is any water inside the DS, the rice can't get inside of it like the water, and won't absorb it.
    Feb 14, 2011 | Nintendo Video Game Consoles & Games
    How do you remove the headlight lens on a 1998 ford escort se , the lens is cloudy and needs cleaning.
    The lens is not removable. Go to Autozone and get a kit to retore your lens to clear again. About $20. You use one chemical to remove the head coat and and another to sand or clean the lens until clear. Then re-apply the hardcoat. Takes under 2 hours. Follow directions carefully
    Nov 01, 2009 | 1998 Ford Escort
    Dishwashers Logo
    21 people viewed this question
    Top Dishwashers Experts
