Question about JVC Televison & Video
Hi I have a jvc 55" 3D smart TV.it wont go to the main menu, no remote function,no sound,and buttons on side of panel not functioning. Only picture and nothing else. Please help Bennie
  • 362 Answers
SOURCE: Can not access menu or input functions
Hi rduncan27,
I will be happy to help. 88% of LCD tv problems are with the backlight, the symptoms you described indicate a probable inverter malfunction. Lets do a simple test to check the functionality.
  1. Get the tv to a point that it is producing sound.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely for a dark video image.
Let me know your findings and we can proceed from there.
Lone99star
Posted on Jan 26, 2009
  • 90 Answers
SOURCE: DELL LCD TV locked up w/screen message "main menu locked"
without a remote and disabled keypad keys, the only other option, is to open the unit up a physically RESET the TV. remove the cables from the power board. i believe it has a phillips head screw. careful when you separate the rear cover from the front cover. there is a board screwed in the lower right corner, there is a connecter and a ground cable screwed to the rear cover. take your time prying on the rear cover. once you separated the two pieces, look for the light yellow board with your AC power source. Unplug it for 30 minutes and repeat the process. while your at it, also look down to the lower left side of the monitor. u should be able to see the keypad. press each button, while pressing, look to see if the button is pressing against the circuit board. it may be loose, try this test, u just may be able to fix your keyboard as well. hope this works out.
Posted on Jan 30, 2009
  • 1779 Answers
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Posted on Feb 04, 2009
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
  • 3 Answers
SOURCE: I can hear the Wii, but not see the picture
You have 1 of 3 problems.
1. The RCA cables (Yellow, White, and Red cables) are damaged.
2. The port on the wii that the RCA cable goes is damaged.
3.The ports on the TV are damaged.
Posted on Aug 05, 2009
Is this tv a smart tv?
Good morning Shelly.
My Samsung smart TVs has a remote like the one in the picture.
In the middle, I hope you can see a multicoloured button that is to put on the smart function. It is best to go to menu on the remote, open Support and scroll down to Contact Samsung, go all the way down, there you see the model and make. You can also visit
Electronics Appliances Tablets Laptops Phones TVs Samsung US
Sep 29, 2015 | Samsung Televison & Video
No picture, just sound on Etec Flat Panel 40A99
Video circuit is separate from the Audio circuit. The main controller may switch to Audio, but if the unit is damaged from a power outage; part of the circuit board may not function. Needs professional servicing.
Feb 26, 2014 | Cars & Trucks
Turn on pip wiithout remote
If your TV has a Menu button on its front panel, enter its Menu widow, surf through, come to wards picture control window, and make PIP function OFF. If it has no such button, you must have its remote control to turn it OFF.
Jun 07, 2012 | Televison & Video
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Have power (backlite) but no screen (menu or any control from side buttons) will not turn off.
Try disconnecting the tv button pcb interface connection to the mai board once switched on and try using your remote control functions. If there is still no menu or functions, this cancels out the buttons pcb, and the fault is the main pcb.The voltages are ok which you mentioned..12v..5v and the 24v invertor feed voltage so it will be the main pcb..If you had sound and remote functions i would have said it may be the Tcon as well as the main pcb.
If the remote works ok with tv buttons pcb disconnected, then the problem is the buttons pcb.However, you have no picture..i presume nothing at all including 'no signal message or menu screen'. Therefore, with no bulging caps and correct votages to the main pcb, you will be right to change the main pcb.
PLEASE DO NOT CARRY OUT ANY ELECTRICAL REPAIRS IF YOU ARE NOT COMPETENT TO DO SO..ALL MAINS PARTS ARE DANGEROUS..GET A QUALIFIED TV ENGINEER TO CARRY OUT ANY REPAIRS IF THIS IS THE CASE.
Feb 14, 2010 | Vizio L32 32 in. LCD HDTV
Tv wont turn on. toshiba 37c3030d
The internal power supply has died. take it to a repair facility.
Aug 13, 2009 | Toshiba 37C3030D 37 in. LCD Television
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
JVC AV-27D500 27" TV
The closed caption or PIP functions in mostly all sets are only acessable trhough the menu.. You need the original remote to do this. If you dont have one go to http://www.remotes.com or call 1-800-remotes for inexpensive exact replacement remote controls. If you do have the original remote and can acesess the menu but the features are not there then theres a problem with the sets built in firmware and the only way to fix this would be to replace the sets microprocessor IC. Good Luck
May 21, 2006 | JVC AV-27D500 27" TV
Televison & Video Logo
16 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
