Question about Home
I had the exact same question Donald had. Trying to find a sink to replace discontinued Americast kitchen sink, 7145. Odd shape undermount with sile stone counter top!!!! Help!!!!!
5 Suggested Answers
  • 10865 Answers
SOURCE: Jacuzzi undermount sink
Your sink is clearly made to be undermounted. No trim ring available. With all of the choices now available for sinks and faucets I would recommend that the jacuzzi sink be removed and that you select a new sink and faucet set to your liking. good luck.
Posted on Jan 21, 2009
  • 659 Answers
SOURCE: Is an acrylic sink durable and stainproof?
Acrylic sinks can stain too. I would go with a cast iron sink if you don't want to worry about stains. Acrylic sinks tend to scratch if your not careful.
Posted on Mar 16, 2009
  • 74 Answers
SOURCE: Can you install a garbage disposal in a corner undermount sink
Are we concerned about the distance between the bottom of the sink and the bottom of the cabinet?
I have installed a lot of disposals on under-mount sinks and I have found the the Badger company has a 1/3 hp unit that is quite short. It may seem a bit small but we need to remember that disposals are not made to chop wood.......1/3 is plenty strong for a person who uses their head when shoving food sown it. Their 1/2 hp unit might also work.
They are available at Lowes and Home Depot for around $60.
Hope this helps
Posted on Apr 28, 2009
  • 62 Answers
SOURCE: installing an undermount sink in case it need to be removed
under mount sinks are 'glued' to the underside of the granite countertop using clear silicone caulking. Clean both surfaces really good with alcohol or acetone (or even disc brake cleaner, apply caulking to bowl flange and position bowl up to underside of counter. Temporarily block in place and let cure for 48 hours. To remove bowl later, use a thin cutting blade like a hacksaw blade to slice through the caulking line. It helps if you don't squish all the caulking from between the bowl and the counter so that you can just get the hackwas blade in there in the future.
Posted on Jun 12, 2009
How good are Kraus kitchen sinks?
Kraus KHU100 Kitchen Sink
A kitchen sink is not an optional part of your kitchen. Therefore, people pick a sink that suits well with their kitchen styles and functions properly with enough durability. It must be a tough job for you to search for a sink that has all these features in it.But you do not have to bother anymore as we brought here a Kraus KHU100 Kitchen Sink review to you. The review reveals about wonderful features and specification of Kraus stainless steel kitchen sinks.
Kraus Undermount sink is a heavy-duty handcrafted kitchen sink with a sleek style. It goes with your traditional or modern kitchens perfectly. You might know that Kraus stainless steel sinks are loved by the customers for their quality and longevity. Consequently, Kraus single bowl stainless steel kitchen sink is well-liked by many because of premium-grade thick steel and outstanding quality.
Kraus Undermount kitchen sink has a lot more impressive traits that would make your choice clearer in buying this efficient sink.
Overview
You might have faced hassles in managing to clean your large and huge utensils in a sink. But Kraus stainless steel kitchen sinks figures out this issue. Kraus stainless steel sinks have a deep and spacious sink to accommodate your enormous kitchenware.
Kraus stainless steel kitchen sinks are engineered for optimal drainage with channel grooves that prevent water pooling in the middle of the basin. Besides its features, the Kraus KHU100 Kitchen Sink review holds the technical specifications of Kraus single bowl stainless steel kitchen sink too.
Specifications
  • Item weight: 26 pounds
  • Product dimensions: 32×19×10 inches
  • Size: 32 inches
  • Color: Stainless steel
  • Style: Sink
  • Sink Shape: Rectangle
  • Finish: Satin
  • Material: 16 gauge Stainless steel
  • Installation Method: Undermount
  • Bowl type: Single bowl sink handmade
  • Basin depth: 5-11 inches
  • Bowl depth: 9 inches or more
  • Technology: Noise Defend
  • Number of Basins: Single
  • Minimum cabinet size: 36 inches
  • UPS Approved: Yes
  • Nose insulation: Yes
  • Warranty Description: Limited lifetime
Mar 18, 2018 | Home
Which is the best kitchen sink model?
Ruvati RVH8300 Kitchen Sink Overview
Ruvati kitchen sink gives you a chef-like experience. There is an overhanging lips on the front and back that provides a track for your cutting board and colander. The ruvati rvh8300 is constructed with 16 gauge premium 304 grade stainless steel and has a satin finish. This provides your kitchen an elegant look that lasts quite a long time.
The overview section of Ruvati RVH8300 kitchen sink Review basically talks about the technical specifications of ruvati sinks. These specifications are equally significant to judge any product before buying it.
Specifications
  • Series: Roma
  • Brand: Ruvati
  • Item weight: 50 pounds
  • Product dimensions: 19×32×10 inches
  • Style: Workstation
  • Finish: Stainless-steel
  • Material: Stainless Steel
  • Shape: Rectangular
  • Thickness: 16 ga
  • Installation method: Undermount
  • Item package quantity: 1
  • Number of basins: 1
  • Number of bowl: Single bowl
  • Drain placement: Center Rear
  • Texture: Satin
  • Assembly: Assembled
  • Certification: Not applicable
  • Special features: Workstation
  • Warranty description: Lifetime
Mar 15, 2018 | Home
Can I drop-on this sink? or only undermount it? Thanks, Brooke
You are only restricted to undermounting these sinks because of there depth in relation to the siting of the tap, that's all. Remember if you place this sink on top you willhave to discreetly raise the tapbase fixing to maintain easy use of the taps
Jul 15, 2011 | Franke MHK-720-31-MB Fireclay Double Bowl...
Crack in farm house undermount sink Kohler
Possible you could use an epoxy or J B Weld to repair it. I have fixed a couple of gas tanks with JB weld it should work on Cast also . It not to expensive and may be a start for you.
May 02, 2010 | Kohler Nice Cast Iron Kitchen Sink
Some padding under my undermounted sink has come off. What is it's purpose? and should it be replaced? Is it part of the undercoat?
The padding under the sink is just a sound buffer. If the sink became loud when the watter hits it just glue the pad back on and you will be go.
It is not part of the under coat.
Mar 16, 2010 | Franke RGX-170 Regatta Triple Bowl...
My undermount sink in kitchen moves back and forth, how do I stop it
If you look underneath you will see mettle mounting brackets with screws try tighten them up.If this wont work the hole might be too big you will have to take the sink up and put silicon or hard as nails under the sink plate
Oct 22, 2009 | NRS A.H. Undermount Large and Medium...
Hope this helps
Apr 26, 2009 | Jacuzzi Kitchen Iron Black Finish...
Mar 13, 2009 | International Thermocast Corp Thermocast...
Jan 21, 2009 | Jacuzzi Kitchen Iron Black Finish...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
