Question about Garden
Can not find the spark plug on a huskee 4200 - Garden
Huskee 4200 riding mower
Request the diagram from Huskee.
Jun 06, 2017 | Garden
Looking for a LT 4200 huskee manual
Operator Manuals
If you don't find it, give them a call.
Also, here is a link for parts manual online:
Apr 27, 2017 | Garden
Replaces battery and spark plugs in my huskee lawn tractor it cranks over but won't fire has full tank of gas and battery is charged what could be the problem?
No spark? Check out ignition coil. Make sure the fuel is turned on if you have an on line hose switch for that.
Mar 28, 2017 | HP Garden
repair manual
Huskee 26750TSC Operator Manual
page 14 shows the spark plug
above the stamped OHV metal cover on the motor
plug might be covered with one of these hard plastic caps
they break often and you can buy new ones
or a stock rubber insulated plug connection
would then suggest a tube spanner or plug spanner
Tiller Spark Plug Parts
cant say if its spark plug is a long threaded long headed type
or a stumpy
Oct 17, 2016 | Garden
I have a huskee lt 4200. When i engage blades it bogs down as tho im in high grass even tho im not. When i disengage blades so engine regains running speed it pops and backfires a few times from carb
As the engine spits from the carb an engine service would be a good idea for a start, including a fuel system clean and a spark quality check.
It would be wise to ensure the blades turn easily by hand and the bearings are in good order.
Jul 11, 2016 | Garden
Huskee LT 4200 Lawn Tractor I had to jump my mower today and mowed for 45 minutes, turned it off, added gas, started mowing again for 30 minutes, turned it off and now it won't start, turn over or...
A couple of possibilities, either the main fuse has blown, they are normally an auto motive design and located undrt the the hood of the machine, or the start solinoid has burnt out.
Jun 18, 2013 | Garden
Huskee LT 4200. I jumped the battery to get it to start. I mowed for 45 min, turned it off, added gas, starting mowing again for 30 min. Turned it off & now it won't start, turn over or crank. I...
try tapping the starter lightly with a small hammer to rule out a stuck armature. Also make sure all of your connections are tight.
Please explain how you "jumped" it. was it with another battery?
Jun 18, 2013 | Cars & Trucks
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
23hp briggs on huskee only runs with full choke>>>??????? any help??
Pull the plugs, reconnect spark wires, and holding plug against engine (to ground the shell) crank engine. Good spark both plugs? Reinstall them, and check the fuel system -- dirty fuel filter, or dirt in carburetor or lines.
Aug 01, 2010 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
