SOURCE: Remote control does not work for my plasma tv
I also had this same problem. Both the original remote and my universal remote failed to give any response on the TV. Normally the green light flashes when it receives a command from the remote. Called LG Support and they made me an appointment with a local repair company for 3 days later. This seemed pretty quick compared to other companies repair times I'd read about. However next day the repair company called to say it would be 5 more days before they could get a Tech to my location (downtown ATL). 8 days was a long time to wait but once tech arrived he diagnosed it to a bad board and simply went to his truck and swapped it out with mine under factory warranty. Everything has been fine since.
SOURCE: CONTROL CODES FOR HITACHI DV-RMPF2
I found the user manual online - directions are:
Turn TV off
Hold RED TV Power button down
and at same time per manufacture of TV...
Hitachi - 1
Sony - 2
RCA - 3
Sanyo - 4
Zenith - 5
Panasonic1 - 6
Panasonic2 - 7
Sharp1 - 8
Sharp2 - 9
Toshiba - 0
JVC - Clear
Mitubishi - +10
Magnavox - SUBTITLE
Funai - AUDIO
Goldstare - DISPLAY
voyageurs60
SOURCE: Volume Control
The volume control shaft lube, over time and heat exposure, will flow down and corrupt the contact between the volume twister and the spring loaded sensor. Pull the cover off the tuner, locate the volume control and take out the two screws holding it in. It looks like a small circuit board with the volume twister attached.
The base of the twister is hooked to the circuit panel by four metal tabs. Pry these guys gently away and pull the twister free. There will be a metal disk at the end of the volume control shaft, and will have a goopy lube residue on the face of it that can be cleaned with electric contact cleaner or some other kind of solvent. Wipe it clean,(do not immerse) reattach, and test. Worked perfect for me.
Good Luck,
F
SOURCE: Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
