Question about Dryers
I have a failed dell d220P-01 adapter. If I get any 12v adapter with the 3 prong plug can I cut off the 220P plug and wire the 3 power wires together to attach it to the other adapter.
  • 13 Answers
SOURCE: generator plugs doesn't match cord
Hey steve. do you really need 240 volts for 120 v. circuits. the reason you have to have an adaptor plug is because on your 220 volt plug in , 2 of tthose prongs are hot and 1 is ground. for safety you need to get a plug adapter ( a regular 120 volt plug end ) run a ground from adapter to ground on 220 adapter. same with nuetral. you also need to ground your generator. there is usaully a ground lug on the bottom of the gen. Another way. if you dont really need 220 v. is to use both 120v. recepticals on gen. Run 2 chords to tranf. switch. and hard wire it in to switch. another way i did mine . when i lost power in this hurricane. i ran two # 10 chords from my 2 120v. recept on my gen to my breaker panel. when you do this you have to pull the service meter, if you dont when power comes back on it would backfeed through your gen.then i turn all my 220v. breakers i was able to run lights ,ciling fans, freezer, ice box,washing machine and gas dryer , tv's computors etc. . but to do this, you probably need someone that knows what they are doin.
Posted on Sep 19, 2008
johnny5846
  • 379 Answers
SOURCE: Wire color scheme for alternator plug.
ok ric , now the tensioner , notice a 15mm bolt head on the tensioner pulley , put a wrench on that 15mm head and turn clockwise , that will unload the tensioner , install your belt according to the belt wrap picture under the hood , release tensioner , and you should be good to go . however ,,,,,
last thing , there are like 5 fuses involved in this circuit , 1.) a 120 amp fuse in the fuse block , left side of engine compartment , 2.) a 60 amp fuse in the same place as #1 , 3.) a 7.5 amp fuse in the relay box - left side of engine compartment , 4.) a 7.5 amp in the left side of dash fuse panel , and 5.) another 7.5 amp fuse in the same panel as #4 . sure is a very well protected circuit ..
good job
J5
Posted on Jan 20, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
SolutionGuy
  • 331 Answers
SOURCE: Kenmore Dryer model 86683100. I need to change
Yeah, red and black go to the outside terminals, white in the center and green goes to the cabinet. What I do is hook up the red, white and black, then I place the green between the terminal block cover and the frame and screw it in tight.
SG
Posted on Apr 05, 2009
SOURCE: Change 3 prong dryer cord to 4 prong
I have a Maytage Gas Dryer Model SDG515DAWW that Starts up fine but once it heats up ahd the gas shuts off the first time it will not come back on. The blower keeps running but no heat
Posted on Dec 14, 2009
Question about Dell D220P 01 Optiplex AC/DC Adapter 220-Watt Power Supply HOW DO I USE THIS UNIT TO PROVIDE 12V STANDALONE POWER?
most power supplies have a switch for 120 and or 220 options just move the switch to what setting you want. most power supplies can be used as a stand a lone power supply, if not than you need to request for a 220 watt power supply the can be used as a stand alone for pc or computer use. most computer retail should have them in stock. look on line or at
www.fryselectronics.com/computer/parts/power_supple/stand-a-lone/for_PC_use/220_watts/
type power supplies stand-a-lone 220 watts computers compatible
Mar 02, 2015 | Dell D220P 01 Optiplex AC/DC Adapter...
How do I install the standard mini inline cord switch. I am a novice.
The cord has two wires.
Use exacto knife or utility knife with sharp blade, slice the wire down the middle for about 2 inches.
Be careful and don't cut into the copper wire.
Now the two wires are separated, like each lane of a road going around a tree.
Cut one wire completely through. Leave the other wire continuous and uncut.
Which of the two wires do you cut?
Go back to the plug and notice that plug has two prongs. One prong is narrower. This prong carries voltage to the lamp, so technically and officially that is the wire to cut.
However you can unofficially cut either wire and it will work fine.
Open mini switch and there are two halves and one screw that tightens two halves together.
Notice inside the mini switch, there are two sharp brass points.
These brass points will penetrate through the wire insulation and into the copper when you reassemble the mini-switch.
So place your continuous wire in the open mini-switch. and place your two cut wires in place where the brass points will push down, you may have to trim one of the cut wires a bit shorter.
Then put the two mini-switch halves together and squeeze them together between fingers, and then tighten the screw.
That should do it.
If project fails, Amazon offers a work-around:
http://www.amazon.com/Woods-13568-Wireless-Control-3-Outlet/dp/B001Q9EFUU
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
Apr 14, 2011 | Leviton Mini Feed Thru Cord Switch -...
I need to replace the 12v cigarette socket in my 2002 SL1. The OEM socket has a 3-prong adapter coming out of the dash, but I can't find a socket with this adapter at the major retail stores (O'Reilly's,...
The 3rd prong in the o.e.m. lighter is a ground. The two pronged generic uses the metal base of the lighter as its'bround. The black wire should be your oem ground.
Simply replace the lighter and plug the other colored wires(other than black) on each post of the unit. If I can be of further assistance let me know. I use to smoke and have replace many lighters in my day.
tom
Jun 21, 2010 | 2002 Saturn S-Series
We have a kenmore 70 series electric dryer, and we have a three prong receptacle, but the plug is 4 prong. What type of adapter do we need?
According to the National Electrical Code, as of 2000 all newer homes are required to have a 4-prong receptacle for all 220VAC appliances. However, if your home already had a pre-existing 3 prong outlet, you shouldn't have to upgrade to a 4 prong. The following link explains:
The main difference is how the neutral (WHITE) and green (GROUND) wires are termnated. In a 4 wire configuration, the neutral and ground are independent of each other. In a 3 wire configuration these two wires are terminated together. The instructions to convert a 4-prong appliance to a 3-prong are at the bottom of the page in the link I provided.
NOTE: If this is a new dryer, keep in mind, some REQUIRE a 4-prong plug even if you have a pre-existing 3 prong outlet. Read through your installation instructions that came with the appliance if in doubt. If this is the case, you will need to have a 4 wire outlet installed by a certified electrician.
If you have questions, please let me know. I hope this helps you.
Aug 02, 2009 | Dryers
I have a 4 prong pigtail
Here is what I believe you have.
The 3 prong plug on your dryer is configured with 2 lines of power and 1 ground. The 4 prong receptical is 2 lines of power, 1 neutral, and 1 ground.
You will have to turn off the breaker to see how the receptical is wired by pulling it out and looking at it. You can then buy a 4 prong plug to match it and only wire up the 3 prongs you need for your dryer and leave the 4th prong empty.
Good Luck and hope this helps
Apr 18, 2009 | Speed Queen AES28AWF Electric Dryer
Generator plugs doesn't match cord
Sep 18, 2008 | Coleman Powermate Premium Plus 6250W...
Chrysler Part No. P56038933AB Radio Wire Color code
1982 to 2001 wiring harness color code Chrysler.
12V constant pink or pink/white stripe
12V accessory red/white stripe
Antenna/Amp turn on white
12V Illumination black/yellow stripe
Left front + dark green
Left front - brown/red stripe
Right front + purple
Right front - blue/red stripe
Left rear + brown/blue stripe
Left rear - brown/yellow stripe
Right rear + blue/ orange stripe
Right rear - blue/white stripe
there is no ground wire in the harness, the metal braided strap is the ground.
use a ring terminal,speed clip, and screw to attach the ground wire from new radio
when replacing infinity radios and speakers, there are 4 wires instead of 2 at the speaker plug. the large gauge blue and black wires are the power supply for the amp, the other 2 are signal wires from the deck and will match up to the wire color codes above. simply cap off the power and ground and use the other 2 for speaker leads.
One thing i hate to see is someone who just hacks off the plugs behind the radio because they are too cheap/lazy/dumb to buy a wire harness adapter for the nice new aftermarket deck they just bought. ive seen everything from masking tape to house wire nuts used to connect wires, and they never last.
there is only 1 reliable permanent way to connect wires together - SOLDER AND SHRINK WRAP!!! whether you're connecting wiring for a radio, fog lights,repairing a cut wire, etc solder those wires, you'll be glad you did when you never have a problem with that circuit again.
This is a listing for part #'s for dash kits wire harness adapters
all part numbers are metra unless otherwise noted
dash kit 99-6700, 99-6701 and 99-6500 will work for most cars
wire harness adapter 70-1817
reverse harness( to replace factory plug that have been cut off) 71-1817
speaker adapter plugs 72-6510, non amped 72-6513 when equiped w infinity system and bypassing fact amps
no antenna adapters are required until you hit 2002 model year.
beginning in 2005 chrysler switched to a high speed LAN system in all its cars and trucks. there is no longer a switched ignition lead in the harness.
Good Luck
Leadispenser
Aug 25, 2008 | Kenwood KDC-MP235 CD Player
HP 5470c - No power
I've done it, using an adjustable power supply all i needed was 12VDC - 2Amp, the power connector going to the scanner is a 4 pin mini-DIN male, so i've ripped of the cable from the original bad power module, cable has inside 2 wires one black one white and a shielding. Black and schielding are connected together and are going to the minus, the white one is going to +12V
guess what? .... my scanner is working again
Nov 25, 2007 | HP Scanjet 5470c Flatbed Scanner
Dryers Logo
18 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
