Question about Bush Audio Players & Recorders
There is no sound through my bush headphone
Sound goes off when headphone jack plugged in
  • 116 Answers
SOURCE: Toshiba A10 headphone jack problem
I think you are on the right track, if the headphone jack is worn and shorting out itll kill the speakers because it thinks headphones are plgged in, ebay would be a good start for parts, maybe even call toshiba and speak to their tech support.
Posted on Dec 13, 2008
  • 5 Answers
SOURCE: speaker/headphone jack won't work
It may not be the problem of sound card,
try following:
1) try uninstalling/reinstalling the sound drivers from device manager.
2) put the laptop to sleep(standby) mode and than wake up.
Please visit http://www.fixya.com/support/t1728089-speakers_work_but_headphone_jack for more details..
Update, if the solutions work..
Posted on Jul 01, 2009
  • 52 Answers
SOURCE: the headphone connection is not working. the sound
check head phones
Posted on Jul 02, 2009
  • 523 Answers
SOURCE: Headphone jack not working
Hi Friend,
The problem is with your head phone it may not correctly connected,kindly check it out or replace with the other headphone and check it.
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Posted on Aug 02, 2009
  • 11 Answers
SOURCE: headphone jack fault on 32" samsung TV
I don't know about replacing a jack but BN94-01208C fits LNT1953HX is the main pcb that has all of the av inputs on it and it is a snap to change.
Posted on Mar 09, 2010
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
Tv goes silent when I put audio jack in to audio out
you suppose to lose the sound the sound is comming from the head sets right
Jan 16, 2014 | Thomson WHP3001BK WIRELESS HEADPHONES
Denon 1908 no sound
Try inserting a headphone plug into the headphone jack and remove it. Sometimes these units have a problem in the headphone jack where the unit thinks there are headphones plugged in even when there isn't. This cuts all the audio output to the speaker jacks. If you never plan on using the headphone jack, you can also go inside of unit and unplug the cable that goes to the headphone jack board. Just make sure you unplug the unit before you do this, the plug is close to the main power switch.
Feb 22, 2013 | Denon AVR-1908
I bought my elderly dad a bush TV for his birthday. I tried to plug in a set of headphones but also need the sound to come out of the speakers at the same time as my mum also needs to hear the TV. I
Get a cheap set of PC speakers and a headphone jack splitter.(the old TV apparently was designed to not turn the speakers off when you plugged in headphones).
Sep 16, 2012 | Bush Televison & Video
I have no sound and then sometimes after a half hour or so i will start to get some sound but it goes in and out. if i use the headphone jack to a speaker then i have normal sound.
The jack means the audio is ok--most likely a damaged socket where the headphone plugs in---there are leafs in it that when the jack is inserted cut the main speakers off---
May 30, 2012 | Televison & Video
Le32d400e sound gone
You might have an issue with the headphone socket where the jack goes---when jack goes in it moves a leaf in the socket to turn off the speakers====try to slightly wiggle the jack in and out===the socket may be cleaned with electronic cleaner.
Mar 14, 2012 | Televison & Video
There is a sound on the computer. But when I put on the headset, it does not work. The sound on the laptop still goes on.
If the sound of your laptop does not transfer to your head phones first ensure that you have plugged your headphones in the proper jack (I know this sounds silly but it happens.) You may have mistakenly plugged your headphones into the mic jack. Secondly if you are plugged into the proper jack try a different set of headphones to verify that it is not a problem with the headphones. If you get the same result with a second set of headphones then your headphone jack may be bad or came unplugged from your motherboard. In this case disassembly of the laptop may be necessary to check the headphone jack. I would wait for a few more suggestions before going that far though. Hope this was helpful.
Barrett Canning A+, Network+, Windows XP Certified Tech
Nov 20, 2009 | Computers & Internet
Sound comes from monitor when i plug headphones in sound still comes from monitor same goes for speakers
check the jack that you have the headphones plugged into. you may have it plugged into the wrong jack.
Nov 06, 2009 | Compaq Computers & Internet
When using microphone sound also come from laptop sound on compaq
Leave headphone plugged in and restart the laptop with headphone jack plugged.
Unplug jack and restart again with no jack plugged.
This is a Compaq factory defect.
Apr 18, 2009 | Compaq Computers & Internet
C785TU problem related to sound
When you plug the headphones in what happens is that inside of the jack the internal speakers  are disconnected and the sound goes to the headphones. If both are playing either the jack is not inserted far enough or  female plug is loose or defective.  Replace or repair the female plug.
Dec 18, 2008 | Compaq Presario Notebook
26 people viewed this question
Top Bush Audio Players & Recorders Experts
 Grubhead
Grubhead
STEVEN MAYAMBALA
Level 1 Expert
Are you a Bush Audio Player and Recorder Expert? Answer questions, earn points and help others
