Question about Health & Beauty
Why does My scooter keeps slowing down and speeding up
  • Jeff Tilburn
    Jeff Tilburn May 19, 2017
    Hi Sandra Davies, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
naic98
  • 23 Answers
SOURCE: ajust speed
Yes, Unfortunately it is a technical solution, the twist grip speed control is a potentiometer (variable resistor) other then limited the amount the twist grip is turned , the only other way to limit the speed is to add a fixed resistor to the "top" end of the "pot", lets say you want a 10% reduction and you have a 1000 ohm pot you would add a 100 resistor to the "top" of the pot, if it doesnt work correctly change the connection to the other endof the pot
Posted on Mar 21, 2009
gewiz
  • 1271 Answers
SOURCE: Mayfair freerider mobility scooter - keeps losing
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
Posted on Oct 18, 2009
gewiz
  • 1271 Answers
SOURCE: I have a Go Go scooter that is an older model. It
Hi, That sounds like the speed pot is faulty,
When going along push the lever in the upwards direction as well as forward , does it speed up ? does it response ? if so then that's the problem.
There could be a issue with the metal key making a good contact when inserted.
Regards
GeWiz.
Posted on Dec 24, 2009
  • 586 Answers
SOURCE: my lake 4 electric scooter
If your scooter should slow down and speeds up on its own without control after being fully charged, then it means the control board need to be checked. It is having some kind of partial contact in the unit hereby causing the scooter to speed up and slow down randomly.
Most times there used to be a breach in the lines inside the control board, that way making the scooter act irregularly.
Have the control board checked and the wiring checked for any partial contact, once that is corrected, the scooter will be able to function the normal way it is supposed to.
Hope this was helpful to you.
Goodluck
Elect_Comp
Posted on Jul 06, 2011
mc1bean
  • 3053 Answers
SOURCE: scooter slows down but gets up to speed again
I believe i know what the problem is. This is a battery issue. What happens over time, is batteries by being charged over and over, eventually get a memory, and cells eventually slowly go dead. Meaning this: Reason, is it feels like someone is unhooking your battery as it slows down, and the reason it starts speeding up after shutting it down a few minutes, is it regains some strength. Batteries when cells are getting bad, they get hot faster when trying to function at full capacity. When you turn it off, they cool a little, and acid in battery slowly drain down, then when starting it up again, it flows up again, until gets hot and does it again.
Conclution: I believe by replacing the battery, this issue will be solved, if for some reason it still does it, only other step is motor is getting worn, where barring is getting hot, and causing the shut down as a safety fire shut down, to prevent further damage. BUT , i doubt that, I believe battery is the issue.
I hope this helps you, Mike from Fixya.
Posted on Aug 09, 2011
My scooter slows down then goes back up again
The problem you have got is the throttle pot is faulty. Get this replaced and it will be fine
Jun 19, 2015 | Pride Mobility Products Celebrity X...
Invacare meteor, keeps slowing down, then speeds up again, can you help.
usual cause of this is the throttle (wig-wag ) controll potentiometer has worn out.to test put the scooter against a wall and get a freind to lift up the rear of the scooter and put 2 large blocks of wood underneath it so the back wheels can rotate
carefully advance the throttle 1/2 way then with wheels turning.keep in same position and gently move the throttle lever up and down .if there is a lot of play and the speed varies drasticaly then pot replacement reqd .you can get a dealer to order the correct one or get one off the internett but when fittinf if thr pot is not set to exact center with multimeter scooter will not move and produce off center error code
Sep 27, 2014 | Invacare Health & Beauty
Slow speed
hi what happening to the battery power indicator while this happens ?
if you are sure the batteries are okay , look at the connections to the rear axle, making sure they are a good clean connection, you be amazed the problems with those connectors...
1. Motor breaking down.. ( Resistance changing ), Brush less motor otherwise check the brushes...
2.Brake coming on so slowing the scooter down.
3.The output stage of the controller is breaking down....
Regards
Rob
www.gewizrepairs.co.uk
Mar 21, 2014 | Shoprider Dasher 4 Adult Scooter
I HAVE A CELEBRITY DX SCOOTER, IT IS 4 YEARS OLD. I HAVE HAD NEW BATTERIES FITTED, BUT THIS LAST 3 MONTHS THE SCOOTER RUNS FROM NORMAL SPEED TO SLOW AND SLUGGISH THEN BACK TO NORMAL EVERY FEW MINUTES.CAN...
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Jul 05, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Regards
GeWiz.
Dec 24, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Mayfair freerider mobility scooter - keeps losing power, especially on slow speed
Regards
GeWiz.
Oct 18, 2009 | Health & Beauty
Health & Beauty Logo
150 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
