Question about Photography
My Roncato suitcase lock does dot open and seems to be jammed. What shall I do' Thank you .
SOURCE: I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Posted on Oct 11, 2009
SOURCE: Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Posted on Dec 04, 2009
SOURCE: presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Posted on Mar 01, 2010
matt2414
  • 247 Answers
SOURCE: How do I reset the combination lock on my
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
Posted on Mar 19, 2010
e-Guru
  • 3917 Answers
SOURCE: My Samsonite oyster suitcase doesn't
Hi
Squeeze down on the lid to release pressure on the lock and gently pry the lock up. Also look behind the lock on the inside of the case there is a tiny part (like a stick shift) sticking out of a square about 1 cm across move it to the diagonally opposite side (some move sideways toward the numbers and then up to hold it in place) reset code return shift to old position.
*For those without the little stick shift part, try this:
With the case open, and the current combo in place, hold down the shackle (the little grey or black button beside the combination numbers).
While holding this shackle down, rotate the numbers to the number YOU WILL REMEMBER. (Holding the shackle down allows the numbers to tumble without moving the divots.)
Let go of the shackle -these numbers are now associated with the divots.
Now your combination should be set to the number you wish.
*For those with combination locks on a zipper hard-shell, try this:
On the bottom edge of the casing surrounding the lock there is a small button. With the combination set to the current "open" numbers, depress the button with the end of a pen or something similar. It should "click" and stay depressed. Now turn the combination settings to a new number YOU WILL REMEMBER. Next, pull on the release button. The button will snap back out and the numbers you have set the combination to will now be the ones that open the lock.
*For those with neither one of the above options:
Try pushing the latch that usually opens the case towards the center (where the handle is) and set the new code while keeping the latch pushed towards the middle.
The latch usually opens the suitcase with the right combination when pushing it away from the middle (towards left and right) for setting the code you need to push the latch in the opposite direction (towards the handle).
Once you have the new lock code set, release the handle and you are done.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 09, 2011
How do I make my lock lock again
Does the red indicator show ?
Is it a padlock or suitcase lock ?
It sounds like the combo has been changed.
Feb 19, 2014 | Locks & Locksmithing
Roncato suitcase forgotten my combination and cant open the suitcase
I have a Roncato hard shell with a 3 digit combination lock under the handle. I set the combination YEARS ago, had a young child play "horsey" on it, and turned all the numbers! The suitcase was locked and I had forgotten the combination. I followed the instructions in answer 2 above and it worked! I didn't have to add or subtract 5. I used a small sewing needle and a strong flashlight - the indentations were easy to see.
Feb 11, 2013 | Samsonite Photography
How to change lock code in TSA007 lock?
Nov 30, 2012 | Samsonite Tripod
Please tell me how to set teh lock code for my samsonite silhouette 11 HS....no instructions were included! help!!
Sure... here're the instructions - open the suitcase, then open the zipper in the modesty pouch (it is mounted on the backside of the suitcase, along its entire length), and then from in there, take out the plastic packet. In the plastic packet are labels, warranty information, AND voila - the instructions to set the combination lock... :-)
I would tell you here too:
1. Open the suitcase
2. Look at the inside back of the lock - you would see a red color tab, and two markings - A
Aug 30, 2010 | Samsonite Silhouette 11 SoftSide 22"...
Apr 11, 2009 | Samsonite Tripod
I have a VIP suitcase with three digit combination lock. Thouh I have not changed the code, it is not opening. It seems to have stuck. I have tried to open it even with a few earlier combinations or my...
I just opened mine. I also knew the the password and the suitcase wasn't unlocking. If you are all sure that u know the password. Then put some oil in the lock. wait for 1 hour... This will help. If it doesn't work then.. Put the lock code and push the clips manually with a pait or scissors or a small blunt knife.. Don't worry the lock is just stuck. After all it's a vip and not samsonite
Mar 21, 2009 | Baby Gear
Presto combination lock on a suitcase will not open
Jan 14, 2009 | Extensis Suitcase X1
Photography Logo
272 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
