Question about Microwave Ovens
I wanted a door for a brother high speed microwave oven MF3250. The door glass has crazed and quite unsafe. The unit has since been slightly vandalised.
Mine suitable for spares only for free if collected soon.
  • 1462 Answers
SOURCE: Microwave oven glass window on the door
do not use - there is a possibility of microwave leakage.
Posted on May 07, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Inner 'glass' of door
The inner glass can and should be replaced. It protects the metal mesh screen from getting dirty, which can cause it to be damaged and allow microwave leakage. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 22, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 24, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
Posted on Oct 09, 2009
Testimonial: "Thanks for your help. Customer Services were no help. Can you please advise which type of caulking to use."
SOURCE: GE Microwave/Convection Oven - Door Glass Just Exploded!!!
This happened to us 3 weeks ago with our 3 year old Kitchenaid microwave. Several hours after its last use it just shattered. In doing research I discovered that this has also happend with GE microwaves, all 3 years old. The cause seems to have been a batch of defective glass supplied by a third party. Whirlpool was very quick to cover the cost of the replacement, even though our microwave was out of warrantee.
Posted on Nov 18, 2009
How can I remove the door glass?
You really don't want to undertake this task.
Feb 16, 2016 | In Microwave Ovens
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
There is dripping marks inside the door between the glass. Can I take it apart and clean it safely?
NO Microwaves are Safety Sealed , Get Proffesional , but ask price 1st , as it may be cheaper to buy a New Microwave.
Mar 15, 2015 | Microwave Ovens
Microwave not heating
Hi Edward
I should mention (although it's pretty obvious) that Microwave Energy is DANGEROUS.
So it's better not to fiddle with the internals.
A quick test can be done to check for electromagnetic energy (in the 2.45Ghz range) inside the oven. Put a glass of water in the Microwave Oven and place 2 strips of tinfoil across the top of the open glass above the water. Put the strips close together but not quite touching then close the door.
Start the microwave & look through the glass window. Listen & Watch for sparks between the tinfoil pieces. If there are sparks then your Microwave Oven is generating or transmitting electromagnetic energy from the magnetron tube unit.
If it's working Don't leave it sparking too long. The tinfoil can get hot enough to burn. The glass of water is to absorb any microwave energy.
There is an interlock switch on the door for safety to protect you from microwaves leaking out of the door cracks. This switch fails to function sometimes. But normally the oven won't even try to power on or spin the turntable (or Fan) if this interlock fails.
If there are no sparks then your Magnetron is shot. Its usually not worth fixing them unless you know of a specialist technician who is qualified and competent with microwave equipment.
Hope This Helps
..... Trevor
Jul 15, 2014 | GE Profile Spacemaker Over-the-Range...
Replacing relay switch in electrolux high speed microwave oven
Sometimes a door latch or magnet closure is a problem. If the door fails to make proper contact when closed, the oven will not start. If the oven goes on and off, there is a disconnect and in some cases the rotating glass dish inside vibrates and causes a disconnect also.
Dec 18, 2013 | Electrolux ICON Microwave Combination Oven
My over the oven model 665.61629100 kenmore has cracked door
The outer door frame CAN be replaced if you like. You can view an exploded view diagram at searspartsdirect.com. Just type in your model number and locate item 10 under the "Door" parts listing. The part comes in various colors so make sure you select the correct one.
The door can be easily removed by opening it all the way and lifting straight up at the hinges. The door will come off the hinge pins and can be laid on a flat surface for easier access. Place a layer of towels under the door to prevent damage to the door.
You will need to remove the door handle to get the outer door frame off. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you may need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and and locate any screws that may be securing the outer door (front) frame in place. Once you install the new outer door frame, re-install the door handle and carefully re-insert the inner door panel. Gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
To answer your initial question, the microwave should continue to be safe to use as long as the inner door seal and door glass are intact. Make absolutely sure you reinstall the door components back together properly. Not doing so will render the oven unsafe to use. Refer to the web site I provided as a reference for how the door components go back together.
NOTE: This part is listed a bit cheaper at appliancepartspros.com. Use the part number from the first website I mentioned as your search criteria.
Jul 30, 2009 | Microwave Ovens
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Glass front on door unglued
First: do not use this unit with the glass improperly installed. Often, these installations use double sided foam tape, available at any hardware store. Carefully remove the screws in the door being careful to catch the glass. Clean the area where the tape will go with glass cleaner or alcohol. Allow to dry and buff to remove oil and grease. Install the tape and glass. Reassemble.
Dec 18, 2007 | Maytag MMV1153A Microwave Oven
Microwave door shattered
Give is the entire model # on the sticker inside the microwave and I should be able to help.
Oct 20, 2007 | Neff H7871N2GB Convection / Microwave Oven
Sep 17, 2007 | Whirlpool MH1150XMQ Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
