Question about Electrical Supplies
Generator runs for 5 minutes then dies - Electrical Supplies
  • 1,830 Answers
Battery operated? Needs new battery.
Posted on May 17, 2017
  • Electrical S... Master
  • 13,163 Answers
You might want to check the valve clearances
Power stroke 414cc HOV
One of the most common problems with power generators is:
Not having been run often enough.
When that happens ( I have 2), the gasoline will evaporate or thicken and turn gummy, and will clog the carburetor.
Then, the carburetor must be rebuilt, (often it has to be taken off the machine) before it will run properly again.
To prevent this, you must start and run the generator once every two or three months for about 10 minutes.
God bless your efforts.
Jul 14, 2016 | Electrical Supplies
Sputters dies after 5 minutes
If it runs at all, then it is not the spark, so it must be fuel. Flush the tank and put in new clean fuel. If it still does not run right, then you probably need to rebuild the carbureator.
Aug 27, 2014 | Honda Eb3500 Eg3500 Em3500 Ew140 Generator...
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Starts easily, run for 5 to 20 minutes and then
If the fuel filter (strainer) is OK, carb gives enough fuel for the load you apply, air filter is dry and clean, your problem may be the low oil level protection.
Check if generator is at level position.
After the oil is distributed in all the engine its level may go less than the measuring sensor level. Try to put some more (not much) oil.
If this will not help your measuring sensor may be bad and switch off when the oil gets hot.
Jul 26, 2010 | Watts Onan Portable Generator - 5000 ,...
Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Nov 05, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical sytem dies then returns when cooled down
Ford has a technical service bulletin out that may fit your concern.
ISSUE:
The charging system indicator may illuminate or vehicle may not start. This may be caused by a discharged battery due to a poor electrical connection at the generator terminal.
2.0L
  1. Replace generator B+ cable with a new Cable (F5RZ-14300-FA).
  2. Replace the generator B+ terminal with a new Terminal (F3RZ-10329-AB).
  3. Install new B+ cable retaining nut and tighten to 10.6 ±1.6 N-m (8 ±1 lb-ft).
2.5L
  1. Replace generator B+ cable with new Cable (F5RZ-14300-EA).
  2. If the generator B+ terminal is damaged, replace the Generator (F6RZ-10346-BB).
Jan 31, 2009 | 1996 Ford Contour
Propane-converted generator sometimes sputters out and dies
I believe the problem may be with the propane. Have him call his propane provider and get them involved. good luck
Dec 26, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
100 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
