Question about HP PSC 2175 All-In-One InkJet Printer
My black cartridge was empty so I bought a new one. When I inserted the cartridge...the screen read "Remove and Check Cartridges." The "Copy", "Scan", and "Photo Card" tabs keep blinking as well. I keep trying to re-insert the cartridges but I am still getting the same message. please, send me the solution- if it possible also at email.. hawleydn@hotmail.com
  • 32 Answers
Hawleydn,
I know this might sound crazy, but your brand new cartridge is junk. Take it back and get a new one. I've done this several times with my HP PSC 2210. the all-in-ones are sometimes finicky with the cartridges. Also, be careful when you insert it into the slot. There is a small wire clip thing on the right side that is easily broken if you try to force it in.
If this helps, give me a vote :o)
samson39
Posted on Jul 25, 2009
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 03, 2011 | HP Office Equipment & Supplies
How to install the ink
Open the front cover on the printer. The print cartridges should slide on a conveyor belt from one far end of the print chamber to near the center. There should be one black ink cartridge and one color cartridge.
Remove the cartridges from the printer. This should simply involve grabbing and pulling the cartridges out. There may be a flap holding the cartridges in place that you need to flip up first. Or you may need to press down on the cartridges to spring them out of place.
Decide on replacing the cartridges with a brand new ones or refilling the existing cartridges. Refilling the cartridges can cost less money in the long-term and reduce waste, while new cartridges will guarantee to work and have the most ink up front.
Refill the cartridges with fresh ink in order to reuse them. With black cartridges, you need to drill or melt a hole in the cartridge lid, while you will remove the lid to find the color cartridge's holes. Inject the correct color ink with a plastic syringe bottle. Reseal the lid on a color cartridge after refilling.
Dispose of the cartridges properly after you purchase new ones. Take the old cartridges with you to whichever store you get the new ones from. Not only will this help you find the correct replacements, but the store may also take the old cartridges for recycling.
Insert the new or refilled cartridges into your printer. New cartridges likely have protective tape over the print head that you'll need to remove. Run a test print on the computer to make sure that the cartridges properly work
Check to see if the printer still reads the cartridges as being empty (if you are reusing a refilled one). This will be due to a chip in the cartridges that the printer reads for the ink level. It doesn't change just because you refilled the cartridges. You must purchase an electronic device that will reset the chip for you.
Chris Thrash
B52Computers
Jan 21, 2011 | Canon Office Equipment & Supplies
Where do you insert the ink cartridges on lexmark x4650
These are the instructions for X2500 Printer
1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
2.Open the top portion of the printer to reveal the ink cartridges.
3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Oct 25, 2009 | Lexmark X2500 All-In-One Printer
Brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    OR
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Error check ink cartridge
    Hi ,
    As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
    Steps >
    Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
    keep on holding the keys down until the machine turns off automatically .
    after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
    Thanks
    MAC.
    May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    HP PSC 2175 All-In-One InkJet Printer Logo
    119 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
