Question about Brother Office Equipment & Supplies
The door wanted brother high speed - Brother Office Equipment & Supplies
What is the role of a high speed CPU in Mono Laser Printers?
it is to transfer the document to the ink system ready for print
Dec 23, 2012 | Brother HL-5340D High-Speed Laser Printer...
Kenmore washer won't fast spin
On most modern Washing Machines there will be an engineers program. To get into it there will be a key or button press combination.
You should be able to reset and control functions from there.
Google your Model with Engineer Program etc.
We have a list of many Service Manuals at: www.spotless-service.com (More added everyday)
Aug 29, 2012 | Cars & Trucks
96 explorer wont blow a/c out of bi level vents also only blows on high
There is a vac control for the blend door to direct air flow. You may have a vac leak between the control and the engine - or the blend door may be stuck.
The blower motor uses a resistor to change speed, high speed bypasses the resistor. Check the resistor for melted wires inside.
Jul 21, 2012 | Ford Cars & Trucks
Printer says recplace toner after I have reset a tone cartridge
I have two suggestions for you.
  1. Have Microsoft perform a diagnostic scan and possible fix in three simple clicks of your mouse. CLICK HERE
  2. Download the latest utilities and drivers from Brother by CLICKING HERE
You might also want to review the instructional video by clicking on the link below:
May 22, 2012 | Brother Hl4140cn High Speed Colour Laser...
The fax on my brother MFC-8460N does not work. it does not pick up a dialing tone when sending and on receiving it rings once says receiving bit nothing comes through. Please help
Your modem setting probably is not compabile with the data rate your phone will support.
From the user manual --
If you are having difficulty sending or
receiving a fax due to possible interference
on the phone line, we recommend that you
adjust the compatibility setting to reduce the
modem speed for fax operation
Press a or b to choose Basic or
Normal (or High).
Basic cuts the modem speed to
9600 bps. Unless interference is a
recurring problem on your phone
line, you may prefer to use it only
when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps.
Press OK.
Press Stop/Exit.
The other thing to consider is do you have tone or pulse dial service from your telephone company?
Mar 23, 2011 | Brother MFC-8460N All-In-One Printer
How do i change a speed dial number on my brother mfc-7340?
Changes to the contents stored in the address book do not become effective in the stored speed dial numbers in Windows®. Description:If you have made a change to the contents stored in the address book, the speed-dial is NOT automatically updated.
If you change the address book entry, please follow the steps below to store the speed dial number again.
  1. Click on the setup button to open the Brother PC-FAX Setup dialog box.
    Notes:
    You can also access the Brother PC-FAX Setup dialog box by clicking start => Programs => Brother => MFC-XXXX or MFC-XXXX LAN (where XXXX is your model name) => PC-FAX Sending => PC-FAX Setup.
  2. Click the Speed Dial tab.
  3. Select the Speed Dial No. which includes the member or group you made a change in the address book, and then click Clear.
  4. Click the Speed Dial No. you want to program.
  5. Click the member or group you want to store on the Speed Dial again and click Add.
  6. The Speed Dial is now registered with the new entry. Click OK.
If you put the patch below, the message that prompts you to confirm the destination number or address will appear when you send a fax using the speed dial. Also the message that indicates changes in the address book do not become effective in the stored speed dial numbers will appear when storing a speed dial.
  1. Make a temporary folder on your HDD [hard disk drive] as the location to save the downloaded self-extracting file, e.g. C:\brodnt
  2. Please click here to download the patch. (7.07MB)
  3. The Brother End-User License Agreement will appear. If you agree to the terms, click I ACCEPT.
  4. Download the file to the temporary folder created in Step 1.
  5. Once downloading is complete, open the folder and double click PCFAXUPD.EXE.
  6. The installation will start. Please follow the on-screen installation directions.
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Brother MFC 7420 All-In-One Laser Printer
I need to change a baud rate to9600 for telephone line. can you direct me please.
How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
Basic reduces the modem speed to 9600
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
14400 bps.
33600 bps..
Jul 29, 2009 | Brother Office Equipment & Supplies
I don't know how to connect fax machine
Fax machines will not work reliably on high speed DSL phone lines.
Mar 03, 2009 | Brother MFC-640CW All-In-One InkJet...
16 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
