Question about Kenmore Sewing Machines
My kenmore sewing machine purchased June 21.2011 has a start stop button which has stopped working model #385 16231
  • Kenmore Master
  • 1,830 Answers
Have your sewing machine taken to a repair shop.
Posted on May 17, 2017
Cannot change stop start button on innovis 1200 sewing machine
The start/stop button won't work if your foot control is plugged in, or if your presser foot is up.
Sep 07, 2016 | Brother Sewing Machines
Brother innovis 4000D. Start stop buttons stuck in red, Machine beeping and screen light but blqnk
If your machine was serviced before purchase and now doesn't work, return it to be re-serviced and made functional.
Jul 05, 2016 | Brother InnovIs 4000D Computerized Sewing...
How do I fix my kenmore sewing machine. Model # 385. 1960180
Consult your manual, the Troubleshooting section. It should explain what the Code 5P means and how to correct it.
Aug 11, 2015 | Kenmore Sewing Machines
Stop and start button and the needle up and down button
have you tried turning it off & then back on again.see if it resets itself.
if that doesn't work see if one of the buttons are hung, if so push on it dislodges. if it's new & none of these things work then I suggest you take it back because the circuit board is mal-functioning.
Jul 24, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Start/stop button problem will the machine run on its own
You have to unplug the power cord to the the foot pedal. The manual doesn't include this. And good stinkin luck with Sears or Kenmore customer service! Just pull the cord out of the machine and the start/stop button will work. Try it on a slower setting at first though. Also, if you need additional presser feet, Singer, Brother, Janome, and possibly other brands will usually work as long as they are the snap on type. I really do like my machine, good luck with yours!
Apr 23, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Feb 02, 2009 | Sewing Machines
Sewing Machines Logo
22 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
