Question about The Office Equipment & Supplies
How do I remove the hard drive from printer hplj4700dtn ?
I wanted to know if the hard drive on a Ricoh Aficio 1018D is a memory or physical hard drive.drive please advise
Most newer printers have a regular hard drive, which retains most information that has been entered. It is advised to remove the hard drive when disposing of the printer.
Mar 02, 2018 | Ricoh Office Equipment & Supplies
How do you clear the Time for Wiper Replace and sponge Replace?
How to erase data off of your printer or copier hard drive ...
? 1:27
https://www.youtube.com/watch?v=HIcBdXU_C_0
Jun 24, 2010 - Uploaded by Jeffrey Bender
How to erase data off of your printer or copier hard drive ... where trained specialist can perform all hard drive services at your location for ... JJ Bender guarantees the safe removal of sensitive documents from your ... How to Remove a Hard Drive Video.wmv - Duration: 4:52. ... Get video URL at current time.
Maintanence Tips - tonerrechargepro.com
Jan 13, 2016 | Office Equipment & Supplies
How to remove hard drive in xerox pro 245 copier
Hard drives in printers? Never heard of such a thing. Memory maybe but not hard drives. Go to the Xerox website and enter your model and they should be able to help you. Unable to help with this one. Good luck.
Jul 06, 2014 | Xerox Office Equipment & Supplies
Where is the hard drive in my Sharp Ar-n450u +
If it has a finisher, remove it. Then take off the cover on the right side. There's a plate at the top center, remove it and the hard drive and its' bracket are underneath.
May 28, 2014 | Sharp AR-M450U All-In-One Laser Printer
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
My aficio 1035 come on and says on the screen hard disk problem.and nothing is working copy fax scanner and printer
You can remove the back of the machine and take the hard drive out.
It has failed. Not uncommon , The stapler will not work without the hard drive. You can pick one up anywhere the sell hard drives. Probably not more than a 16 gig hard drive, but it will work with out it, just leave you a small message that the hard drive isnt working.
Jul 15, 2010 | Ricoh Aficio 1035 Copier
Getting error code 04C300 00310000
Hi;
if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
May 26, 2009 | HP DesignJet 1050c InkJet Printer
Downloading hardware
Simply connect your removable hard drive to a usb port of the computer with internet connection available, then open your browser and type www.hp.com.......>> go to software and drivers >>
put y our printer model >> Select your OS >> and download the drivers
Select SAVE AS.......and choose location on Your Removable Hard Drive........OK
Then unplug your removable Hard drive and conect to the laptop USB port.....
Then go to Start >> Control Panel >> Printer...........ADD A printer
Follow the instruction and Select ......Specify Location........Browse..........
And choose your removable Hard drive to finish install the drivers
for your printer
That's it.
Oct 30, 2008 | HP PhotoSmart 7150 InkJet Printer
Hard disc
Switch off the Printer and remove the Power Cord.
1. Remove 6 T-15 screws (Type B) from
the HDD Access Cover. Remove the
HDD Access Cover.
2. Remove the HDD with its foam holder.
3.
Disconnect the HDD Cable and Power
Supply Cable from the HDD.
When Installing the Hard Disk Drive make sure the holder is
placed in the right position so that it cannot move.
When the Hard Disk Drive is
replaced perform the
following Service Utility: Backup EEROM
Backup EEROM
This Service Utility is used to restore the contents of the EEROM
when a service engineer has replaced the Main PCA or the Hard
Disk Drive. If the Main PCA is replaced the EEROM content,
backed up on the hard disk, is restored to the Main PCA and if the
Hard Disk Drive is replaced the EEROM content is saved to the new
Hard Disk Drive.
Before using this utility, make sure that you are using Firmware
version A.02.xx. If NOT, make sure that you upgrade the
Firmware version to A.02.xx BEFORE using this utility.
1. In the Service Utilities submenu, scroll to "1.6 Backup EEROM"
and press Enter.
2. Select the part that has been replaced and press Enter
3. If you select "Hard Disk Drive (HDD)" a message confirming
selection is displayed. Press Enter to confirm and exit this utility or
press Back to cancel.
4. Press Back to return to the Service Utilities menu.
Sep 23, 2008 | HP Designjet 5500 (42 in.) InkJet Printer
System Error 04C300 00260000
System Error 04CXX Try the following Steps to resolved an eror:
Aug 21, 2008 | HP DesignJet 1050c plus InkJet Printer
18 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
