Is there a switch on the TV to change it from Channel 4 to Channel 3? Remote does not work
SOURCE: Skipped channel 4
I have the EWF2004 emerson TV. I tried a ONE For all universal remote and programmed it for a FUNAI TV code 0179 and it worked!!!!!!
Posted on Oct 05, 2008
  • 285 Answers
SOURCE: I can't change the channels on the tv with remote or on tv contro
You will need to rescan for channals, or manually enter the number. Make sure your sat. box is on when you do this. Rescan can be found in your tv.s menu.
Posted on Jul 03, 2009
SOURCE: Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Posted on Oct 25, 2009
  • 374 Answers
SOURCE: Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Posted on Jan 11, 2010
  • 309 Answers
SOURCE: Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Posted on Jan 24, 2010
Can't change channels stuck on 4 tried scanning it but it goes back to 4
There could be a few possibilities for this .:
  • Change the "Input" setting on the TV to "AV" or "VIDEO". There is probably an "INPUT" button on the remote.
  • Find the TV/VIDEO mode on your tv or check the back of the cable box where your cables screw into the unit. There is normally a switch to select an output for channel 3 or channel 4. Your's would be on 3. It's just a matter of switching to 4 to make it work on your tv. More info on this here:
  • https://www.google.com/search?q=tv+channel+stuck+on+4&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
Jan 28, 2016 | Televison & Video
My tv needs to be on channel 4 but I can't change the channel it's stuck on channel 3 what should I do
Why can you not change the channel? The only way to change channels is either on the TV directly, or from the remote. If neither work then you may need to get a new remote, or a new TV.
Nov 15, 2014 | Televison & Video
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
Jan 24, 2010 | Televison & Video
We have DirecTV and is is on channel 4. My
Use the tv remote to put the tv on ch 4. Use the direct tv then to select channel of the direct tv box. The box is broadcasting to the tv on ch 4. Also check that tv is on correct input . Again use the Panasonic remote to select correct input. If this does not work call direct tv for assistance.
Dec 03, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Mar 23, 2009 | Sharp Televison & Video
Can't re-program channels
Use the channel switches and vhs switches to get the on screen tabs to work.....
May 23, 2008 | Emerson EWC1304 13 in. TV/VCR Combo
Trying to watch vcr on channel 4, but the vcr is set to channel 3
You can watch the TV programs
with the tuner of the unit. (Usually
channel 3 or 4 of the TV is
available for the RF converter
setting.) Be sure to connect the
unit to a TV using the RF cable.
Select channel 3 on your TV.
Press [VIDEO/TV] on the remote
control.
• If noise appears, change the
RF output channel of the unit to
CH 4 by pressing [VIDEO/TV]
for 3 seconds. The RF output
channel will alternate between
CH3 and CH4
Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
Buttons/ Remote won't operate TV
Defective tactil switch?? Remove tact switch control board.
unplug connector,use meter--check each switch.
If no problem found,leave unplugged overnight or longer.
Sony is famous for getting brain freeze!.........T.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
