Question about Dishwashers
I need to know the code for hot water for rental properties
My landlord only allows me to have luke warm hot water. I have to boil water to wash dishes and cnt take a bath due to temperature of hot water.
4 Suggested Answers
landsend
  • 1066 Answers
SOURCE: Water not hot on hot temperature setting
BS ....on the back inside the washer are two solenoid operated valves that control the hot and cold water flow. your hot valve has ceased to function...and needs replacement.  also make sure your hot water valve is open fully and that the screen inside it isn't clogged.
Posted on Apr 03, 2009
snowghost1
  • 784 Answers
SOURCE: My Bosch tankless hot water heater is not heating
sounds like the temperature sensor could be bad or the temperature control valve is bad.
it is one of the two.
c...
Posted on Feb 15, 2011
FirsLonewolf
  • 186 Answers
SOURCE: Reliance 501 electric water heater with 4500 watt
likely the elements are corroded you should turn off the power to the heater, then turn off the water supply to it and the exit shut off as well. Then drain the tank, remove the old elements take one with you to a local hardware store which should have replacement elements or will tell you where to get new ones.
once you have replaced the elements be sure to fill the tank and open the exit valve before turning the power back on.
Posted on Sep 21, 2011
No hot water
Lady may be tight, but she demands her rent on time and you no doubt pay more than the rental is worth. Most State Laws require landlords to make repairs within a reasonable period of time after the renter request service. Tight or not; she is responsible for the rental and you have Renters Rights. If you can't get her to fix the problem, withhold the rent and see how fast she reacts. Tell when she fixes the problem (In writing) you will pay the rent. If she tries to mess with you, report her to the State Rental Authority.
Mar 05, 2014 | Intertherm Heating & Cooling
Jura impressa j9 latte temperature
put in microwave , use hot boiling water , descale .
Dec 15, 2013 | Jura Impressa J9 One-Touch TFT Espresso...
Worcester 35cdi water and heating luke warm
First thing is to know when it was installed? Check the top of the unit and see if it has in and out marks on it. If it does are they correctly hooked up? Installing them backwards causes this.
Jun 04, 2013 | Water Heaters
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
WATER IS COLD DURING HOT RINSE
Hot water heater may need to be re-lit. If it is a rental, and a electric water heater, you may want to call your landlord.
Jun 08, 2011 | Dishwashers
I have a single lever bathtub control for hot and cold water, but cannot get shower activated. Only have the up and down lever to open and close tub. What am I missing? I am in a new rental and the...
The lever that you are moving controls a water diverter in the pipe. It may be broken and need replacement. I'd ask your landlord to call a plumber. Good luck!
Mar 10, 2010 | Delta T13420 Chrome Classic Single Handle...
Cold water is leaking on to hot side causing luke warm water
i have a 7570 salora that took the top off and i can't get it back together right
Feb 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Mar 29, 2009 | Kenmore 22422 Top Load Washer
Dishwasher doesn't wash with hot water
just about ALL dishwashers only fill up with cold water (one pipe) the machine warms the water up etc, simple one to solve, just connect up so and use it, one cold water in, one waste pipe out
Oct 03, 2007 | Dishwashers
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
Owen Barnes
