Password reset for 1st setup - Computers & Internet
I lost my password. i would just reset the router. but i only have the disc that came with the router. an its a 32bit disc. an my computer is a 64bit operating sys. when i bout the computer they only had...
Hi.
You can reset and enter your router manually using your internet browser.
In the www field enter 192.168.0.1 user id is : admin and password is : password or 1234
You will enter the setup page of your router and you should have a wizard to help you configure your internet access point.
Feb 13, 2011 | NetGear WNR2000 Wireless Router
Dont have password for phoenix BIOS setup page or the user name and password at startup
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some hard tutorials, it is difficult to do. It is better that you are a expert. For example this tutorial: Bypass BIOS Password or Crack CMOS Password?
3. Use the bios password recovery tool , but that is not free!
So I would suggest you the 1st method. Hope it helps.
Dec 20, 2010 | Compaq Presario 1230 Notebook
I forgat my. Administration user account and I need to axces to my acer one
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ++ keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2nd Method:
A. Boot using Windows XP Setup CD and follow the instruction like Accepting EULA, etc.
B. When it asks to repair your existing Windows installation, accept it and press "R" to run the repair.
C. Setup will start repairing your Windows and will start copying files, etc.
D. After a few minutes setup will restart your system and when it restarts don't press any key when it shows "Press any key to continue..." otherwise Setup will start from the beginning. Don't press any key and setup will resume where it left.
E. Now it'll start doing other tasks and will show a small progressbar with a few details in left side.
F. Look carefully at the details and when it shows "Installing devices", press +F10 keys in your keyboard.
G. It'll open a Command Prompt window. Now type nusrmgr.cpl and press .
H. It'll open the same "User Accounts" window which you see in Control Panel.
I. Now you can remove or reset any account password without any problem.
Dec 03, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have a password on my computer, after an extended vacation I can no longer recall what it is, how can I access my data again?
you forgot to tell us what password.
Is it a bios password or windows password?
For Windows Password, As far as I know , there are two main methods to solve the windows password problem as follows:
1st Method:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type \Administrator\ (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from \Control Panel - User Accounts\.
2th Method:
Windows password Recovery software:
for example:Windows Password Recovery . It is easy and convenient to use.
For Bios Password, also two methods.
1st method . Open you computer box and Discharge to the Board manually
2st method . use BIOS Password Recovery
Hope it help to you.
Sep 18, 2010 | Acer Aspire 5500 5570-2609 Laptop
I lost my configured password for setup in BIOS
2. Follow some hard tutorials, it is difficult to do. It is better that you are a expert. For example this tutorial: Lost BIOS Password?
Sep 01, 2010 | Dell Latitude D400 Notebook
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
Mar 02, 2010 | Computers & Internet
I'm trying to connect to my actiontecj GT704WG
hi!. reseting the router is your last option, but 1st try to connect your laptop directly to the router using an ethernet cable and access the setup page of your router and go the wireless settings of the router and you will see the wireless security and password.. to access the setup page u need to check the default gateway of your router, how? click on start, run and type in cmd, it will show the dos prompt and type ipconfig/all, it will list ur ip address, subnetmask and the default gateway.. ex. 192.168.1.1, then pull up the browser and type at the url-192.168.1.1 and it will ask the username and password for the router, u need to type in the username and password for the router so that u can access the setup page..I hope this will help ur problem
Aug 10, 2009 | Computers & Internet
Rest password on DNA-A211-I ADSL2+ Modem
hi..
the only way to restore the router is to hard reset the router,which will reset the router to the factory defaults and then setup the router as the first time installation and the default username and password will be restored,i kno this is much of a work to reset the router and again setup the router like 1st time installation but this is the only way to retrieve the default user name and password..
vedhick
Jan 15, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dell inspiron 1501 laptop
Two Scenarios here 1) It is a notebook setup for a network and 2) Not on a network - you have setup the password yourself for your own security purposes.
In the first instance this can be easily solved by requesting your network administrator to reset your password. In the second scenario you can do three things 1) Re-Format and Install the OS again (in which case you will loose all data (2) Get a good password cracker (downloadable everywhere "Google-it" (3) Keep on trying until you get lucky (in the 1st scneario Keep on trying until you get lucky will not work as you will get logged-out on the 3rd or so attempt. Sorry but your'e in a bit of a spot and there is no easy way out except if it is the first scenario.
Good luck
Apr 19, 2008 | Microsoft Windows XP Professional With...
Need XP Professional password for Dell Latitude D600
Assuming Windows XP.
Boot into safe mode. Do so by pressing 'F8' a few times just as the computer begins to boot up (right before the Windows screen)
Once in safe mode, click on administrator (or type it in as the username if it doesn't come up with the welcome screen). It shouldn't, by default, have a password if it is XP Home.
Once logged in as administrator, go to control panel and users and change the password on the account you want or create a new one.
Dec 20, 2007 | Dell Latitude D600 Notebook
Open Questions:
Computers & Internet Logo
David Payne
David Payne
