Question about JVC Televison & Video
My TV is showing a message on the screen, it says that, I need to change the lamp light for the timer and press this button to stop this message.
  • 4,234 Answers
These lamps have "lifetimes" that average x hours. The TV keeps track of the use hours and will display the message you see when that time has elapsed. While the lamp may continue to finction, it may not be generating full light output. You should change the lamp as soon as you can get one.
Dan
Posted on Jul 25, 2009
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Tip
Procedure to reset Panasonic TVs
If you have replaced the lamp in your Panasonic DLP TV and are having problems such as a message on the screen telling you to reset the lamp timer or the unit not powering up, you probably need to reset the lamp counter. All DLP and LCD TVs which have high intensity lamps generally need to have a lamp timer circuit reset after a lamp change. The manufacturers want to give you a heads up prior to having a catastrophic event such as a lamp exploding which could cause a fire as well as other damage.
Therefore in many cases until you reset the lamp timer the unit will not operate or it will keep reminding you to reset the lamp timer which is very obnoxious. This is not a hard procedure but you will need the original factory remote to accomplish the task. Generally the procedure involves pushing a sequence of buttons.
I recommend placing a piece of masking tape on the rear of the TV with the date the lamp was changed to make it easy to remember when the next lamp change will be necessary. Also you could purchase a lamp now to avoid paying more in the future.
The following procedure should solve your problem:
1. Turn on the television.
2. Press the down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
on Oct 28, 2010 | Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    I have a large screen panasonic tv. The lamp
    Turn On tv.
    Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
    Hope this info will help you.
    Thanks.
    Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
    I have the lamp,the tv is still not coming on. Is there something that has to be reset?
    Yes. You will have to reset the lamp hours. It should be in your owners manual.
    Copy and paste this link in your address bar if you don't have the manual:
    50VS810
    http://tv.manualsonline.com/manuals/mfg/hitachi/hitachi_projection_television_product_list.html
    I have heard that this may work on your tv
    1. Switch power ON, and press the TIMER button on the remote control transmitter, or the RESET button on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear on the lamp timer on the bottom of the screen.
    2. Press the MENU button on the remote control transmitter, or the RESET button on the control panel, while the lamp timer is displayed. The 'LAMP xxxx [] -> 0 [|] CANCEL' message will then appear.
    3. Press the [<|] and select 0, and wait until the timer display is cleared.
    Sep 09, 2009 | Hitachi 50VS810 Television
    Need to reset the lamp time on my PT-52LCX66
    To reset lamp timer in Panasonic PT-52LCX66..
    Press and hold Volume Down button on TV front and press and hold 0 (zero) button on TV remote at same time for 6 seconds, a lamp reset message will appear on TV screen.
    Thanks.
    Sep 02, 2009 | Panasonic PT-52LCX66 Projection Television
    How do i reset the lamp meter after i change the lamp
    Press and hold "Volume Down" button on TV front and press "Play/Split" button on TV remote control for 6 seconds, Lamp Timer Reset message will come in screen.
    Aug 07, 2009 | Panasonic PT-60LC14 60" Rear Projection...
    Set timer
    You did not post model number of TV so try below method to reset lamp timer.
    Turn TV ON, Press and hold Volume minus button on TV and press Split/ Play button on remote for 6 seconds, lamp reset message will appear on TV screen.
    Jul 02, 2009 | Panasonic TY-LA1000 Projector Lamp for...
    How do I reset the replace lamp message
    Do you have a picture? If so the only way to reset this unit is to get a Zenith programmer remote. With this remote you can get into the service menu and reset the lamp timer and that will reset the unit.
    Dec 31, 2006 | Zenith D52WLCD 52" Rear Projection...
    Televison & Video Logo
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
