My son went to plug in the vacuum and there was a loud pop and now the vacuum will not turn on. Any ideas on what happened and how to fix it?
4 Suggested Answers
SOURCE: off/on switch does not work
It really worked,
Thanks for this uggestion!!
Posted on Nov 05, 2007
jmeredith
  • 417 Answers
SOURCE: TV made a loud pop
hi,
sounds like a popped power capacitor, its going to have to go to the shop most likely around 100.00 repair. taking the back off yearly and airdusting them helps, especially if you have a smoker in the house. caution high voltage present even when off, the heavy single red wire going to the tube is high voltage be careful.
J
Posted on Jul 11, 2008
  • 1030 Answers
SOURCE: One of my sons friends
have you tooked the bulb out and checked it.. the bulb makes this kind of noise when it blow
Posted on Oct 28, 2010
93 harley FXR made loud pop from exhaust then started after second attempt. Went on 50 mile ride came home and parked then when I went to put the bike away for the night bike made loud pop again then...
Popping (backfiring) is usally a sign of one ot two things: either the fuel mixture is too rich, or you have a weak spark in one or both cyclinders. Pull a spark plug and look at the tip. If the electrode is coated with black carbon, the the fuel mixture is too rich. Assuming your air cleaner is not plugged with debris, this requires resetting jets in the carburetor. If the culrpit is a weak aprk, replace the spark plugs and see if that fixed the problem. If not, have your coils and ignition wires checked out.
Nov 25, 2014 | Motorcycles
I have a Toshiba 1080i DLP hdtv.. my son & i were
the lamp exploded it happens u need to replace the lamp ensure its the exact type, the lamp is the light source and without light the dmd cannot sync colours nor pix
Jul 10, 2013 | Televison & Video
Hitachi rear projection model 57f59a makes loud popping sound from time to time
Yes and it is common---the set uses 3 picture tubes and where the high voltage (well over 10,000 volts) goes into the side of each tube via a spark plug type wire (with good reason) they completely seal the rubber clip that inserts the wire into the side of the tube.
You are describing almost perfectly when one of the tubes arcs around the anode (what the opening is called--2nd Anode to be precise)
Two things are going to happen--when it pops it can instantly burn the coating off of the offending tube's screen resulting in a burn mark--usually dead center and if red tube arcs the mark will be yellow(only red and visable in that area of the screen.
This damage is permanent once it happens-----Second is that it will arc hard enough to blow some other part out in the set.
let me know if questions.
Mar 19, 2012 | Televison & Video
Speaker pop
Volume is up to high to begin with or there could be some power source close to the unit that is causing it. Turn down or turn off volume and try to do it. Thsi isn't a broken system it does happen to some units, mine included butr when I do the things I have listed it is much better. It is worse with my better sound systems.
Dec 22, 2009 | Onkyo HT-S5100 Theater System
Zenith Plasma
My TV has a picture but its very poor quality and its fading ,blurry color it is not clear what can i do to fix.Thanks
Jul 21, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
No picture
The suggested repair is correct - "won't happen again" is a pipe dream. Best you can do put a UPS on the TV, which addresses one situation.
Jun 19, 2008 | LG 42PC5D Television
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
