Question about Bosch Water Heaters
I need please the manual for spare parts for confort 14 Bosch water heater manufactured in Portugal. I need to buy spare parts. Can you please help me?
mrhotandcold
  • 248 Answers
SOURCE: On-demand Bosch Confort 13 water only works intermittently
will still be under warrent call supplier
Posted on Oct 25, 2009
packrat1948
  • 528 Answers
SOURCE: need a english manual for
http://www.bosch-climate.us/support-center/downloads/
Posted on Feb 07, 2011
SOURCE: I have a Bosch confort
Your contractor understand the market there, but problems are mirrored in US also.
As evidenced by fixya.
1) Tankless cannot be exposed to more than 11 grains hard water, and require minimum water flow and water pressure or sensors will shut down burner or element.
2) For example, tankless might turn on with 2/3 gallon-per-minute water flow, but then another faucet is turned on so pressure and water flow drop, and tankless turns off. Or neighbor's water usage causes decrease in line flow, so tankless turns off. This is called 'cold water sandwich.'
3) If problem is water pressure, you can add in-line pressure tank, but root causes vary widely with more than one factor as suspect.
4) Also incoming water temperature can be a factor, along with temperature setting of unit. Most tankless are preset to 120 degrees F, which is modest temperature and certainly not very high. If tankless cannot raise temperature of incoming water fast enough, then tankless turns off. Of course water flow continues, so you get dose of cold water.
You can add simple120Volt 30 gallon tank-type electric heater as a tempering tank that pre-heats water either passively or actively: http://waterheatertimer.org/Tempering-tank.html
5) Both internal and external factors affect tankless, with bottom line that these high-tech devices are not do-it-yourself repair for most people.
6) Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
7) In my opinion, the genius of tankless is not that they save money or energy. Because they don't.
The genius is marketing that targets a certain affluent who believe tankless save money and energy.
http://waterheatertimer.org/pro-n-con.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 23, 2011
elitecgdwolf
  • 744 Answers
SOURCE: can i get a manual on a bosch gruppe water heater
Having problem finding one. Is there a model #?
Also what are you trying to find out? as sometime googling the problem finds a solution faster than googling manual.
Posted on Nov 25, 2015
My pieps froze and now my tankless water tank leaks how do i get a new part
Bosch Aquastar 125B Water Heater Repair Parts Pre January 2003
Bosch Aquastar 125B Repair Parts Selection Grid
This web site has Aquastar 125B parts. It appears your unit was manufactured 7/7/02, so that is what I pulled up for you. At least this will be a start for you to locate the part. I hope these links work.
Bosch Aquastar 125B Water Heater Repair Parts Post February 2003
Mar 27, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch Confort S 13 BP tankless water heater won't ignite, It clicks but no gas going thru valve
The S 13 BP is a simple unit that does not have a pilot light. It uses electronic ignition on demand, which is what you hear clicking. If there is no gas going through and you've verified there is gas to the inlet, then it has to be the gas control valve.
Feb 01, 2013 | Bosch & Tankless LP Hot Water Heater
My Bosh 24ES has error code 14 what does this mean and can I fix it
The year 2009 Bosch 24ES manual does not show error code 14.
Your manual may be different.
Call Bosch 1-800-642-3111
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch-GWH2400ES.pdf
Don't forget to read the product manual for required yearly maintenance, and performing this maintenance will eliminate many common error codes.
Aug 09, 2012 | Water Heaters
Will not fire at all, trys to light but get the e1 code . used to work intermitently or fire right of way but then go cold and back to hot for about five min. then stay hot now wont even light
Before calling service technician, open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Bosch_E1_troubleshooting.pdf
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/
http://waterheatertimer.org/Crossover.html
Before installing tankless water heater, read the service manuals and product manual to make sure you have testing skills and equipment needed to repair tankless gas water heater, and that you are prepared to buy expensive parts when needed and do the recommended yearly and monthly maintenance as outlined in manual.
Also check that area has qualified service technician, and that person carries parts on-hand, and is certified for your model number. Keep Tankless manufacturer contact information on-hand, and be skeptical of promises of unlimited hot water, and effortless long-lasting water heating, and saving money. The only folks saying this are the folks selling the product, and not their customers.
Fix most tankless gas water heaters yourself, same day, all brads for about $350.
Sep 21, 2011 | Bosch Water Heaters AquaStar 250SXO...
Aquastar125WP is overheating and the strainer has been removed. We need to fix it. Have any ideas? Thanks for your support, Martina
The problem could be bad gas control solenoid, or bad sensor, or bad wiring or bad PC-board, etc, or combination of problems. Fixing one problem may not completely fix problem.
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/38b-125-series-bulletins.html
Before installing tankless water heater, read the service manuals and product manual to make sure you have testing skills and equipment needed to repair tankless gas water heater, and that you are prepared to buy expensive parts and do the recommended yearly and monthly maintenance.
Also check that area has qualified service technician, and that person carries parts on-hand, and is certified to service your model number. Keep Tankless manufacturer contact information on-hand, and be skeptical of promises of unlimited hot water, and effortless long-lasting water heating, and saving money. The only folks saying this are the folks selling the product, and not their customers.
Sep 21, 2011 | Water Heaters
Hi i have a Bosch hi flow 22e model ys2439rxb it is coming up with a fault 14 any help greatly appreciated
I can help steer you to resources, including Bosch contact numbers and possibly your manual and other helpful information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Solve most tankless problems yourself, same day, any brand for $330.
I need some upvotes for the free, hard work being done for folks.
May 03, 2011 | Water Heaters
Water Heaters Logo
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
